2019 Ural Factory tool roll
Geckoboy49
Post by Geckoboy49 » Tue Sep 10, 2019 5:32 pm
So, I noticed past posts mentioned items like a hand pump and tire irons as being included; these must've been phased out as my factory tools are several end wrenches, a few right angle Allens, pair of pliers, combo screwdriver/handle, wrench for the nut on the spare tire mount, leverage handle for the end wrenches, wrench for adjusting pre-load collars on the shocks, a T15 Torx screwdriver (what's that for?) and a 5/8" box/end wrench (what's that for?) Oh yeah, and a pair of cheap gloves. I've added some sockets, 3/8" drive ratchet handle, several socket-Allens. With the spare tire on the GU, did Ural figure tube swaps were a thing of the past??
Now:
2019 Ural GU
2014 KTM 1190 Adventure
2017 Honda Grom
Then: Assorted Harleys, Kawa Z1000, Kawa KLR 650 x2, Suzuki DRZ400, assorted dirtbikes
Re: 2019 Ural Factory tool roll
Post by Tomcatfixer » Tue Sep 10, 2019 5:39 pm
You're not missing anything with the air pump.
Post by sKiZo » Tue Sep 10, 2019 5:49 pm
Still a good idea to have a pump though. Some real decent compact 12v units available at reasonable prices.
PS - something that may not occur to a lot of folk. If you have a battery tender (and you really should) you should already have a handy power tap available for direct battery hookup for any 12v accessory - like the pump for instance. The popular brands of tender use a standard two pin trailer connector that you can get at any auto parts if you have to modify the pump.
rehab circus
Post by rehab circus » Tue Sep 10, 2019 6:07 pm
Yeah, no tire irons with my 2019 tool kit either. The 5/8 wrench is for the parking brake adjuster bolt. I bought a cheap 12v compressor from the local auto parts shop. It works MUCH better than the old Ural hand pump.
:cheers:
Eric
2019 OD Green cT.
UralCanuck
Post by UralCanuck » Tue Sep 10, 2019 8:53 pm
Found the same thing with my 2019 GU. No pump and no tire irons. Dealer confirmed the pump hasn't been included for some time, but was a bit surprised the tire irons weren't there. I did a bit of searching to find a list of what should and shouldn't be included just to make sure I wasn't missing anything else, but couldn't find anything for 2019.
2019 GU
Post by chaos2 » Tue Sep 10, 2019 9:43 pm
Maybe they figured with all 4 wheels interchangeable now a rider would rather swap wheels than bust a tyre. I certainly would.
Michael W
Post by Michael W » Wed Sep 11, 2019 2:43 am
I did not get a pump or tire irons on my 2019 Gear-Up.
2019 Ural Gear-Up, O. D. Green. :clap:
Santa Susana, California.
robp
Post by robp » Wed Sep 11, 2019 8:33 am
+1. Heads up: Note that the standard fuse in the battery tender lead is 3 amps. I bought a 12V mini compressor which draws 5 amps which blew the fuse after a few minutes' operation.
Post by rivers » Wed Sep 11, 2019 11:40 am
Interesting. Ive got a few(4?) Deltran Battery TenderPlus units along with a couple pigtails that I bought without the chargers. They all came with 7.5A fuses. Haven't blown a fuse yet.
Post by RC20 » Wed Sep 11, 2019 12:02 pm
One (device more than tool) I have added is a magnetic tray.
Works wonders so you don't loose those fasteners and possibly other ferrous bits if you have taken things really apart.
I have added a combination wrench for each metric size.
And no I too do not know what the itty bity Torx tool is for.
Post by Tomcatfixer » Wed Sep 11, 2019 12:18 pm
I don't remember, since I've long since removed my cT's annoying parking brake mechanism, but are the four bolts that hold the parking brake splined actuation arm travel limit bracket to the Hayes brake caliper Allen or Torx?
Post by INSUBORDINATOR » Wed Sep 11, 2019 1:18 pm
I like carrying a pump - because valve cores ain't what the used to be, last few years I've had some fail away from home. I found THIS GREAT PUMP
for under $10. It works perfectly. See Pix
Also bought a fantastic tool roll on Ebay - between factory & added items, I'm well prepared. It's much nicer than the expensive Ural too roll & only cost $12.
Michael W
Post by Michael W » Wed Sep 11, 2019 3:20 pm
They are torx, but I think they are T30. The small torx driver is a T15. I don't know what it is for yet.
Post by windmill » Wed Sep 11, 2019 11:29 pm
The little Torx is for the screw securing the injectors
Michael W
Post by Michael W » Thu Sep 12, 2019 12:59 am
Good to know, Thank you.
