Twin discs up front?
Re: Twin discs up front?
Post by Claus » Mon Feb 11, 2019 3:27 pm
Yes Sir. That´s what I wrote:
and a bigger master cylinder (15 mm)
The 15mm is for dual caliper the size we talk about. A small caliper on the sidecar could do with a 15mm as well, a 16mm (or 5/8") will be a tad too big
Post by Mr Wazzock » Mon Feb 11, 2019 7:18 pm
Claus wrote:
Sun Feb 10, 2019 8:35 pm
Take a look on the lower mount of the caliper holder, where the axle goes through. If you make a new holder, it must be the same type of construction (the caliper [holder] must be able to rotate around the axle)
Yes this has a rotating bearing, or at least a bush, against which the spindle can be tightened, but leave the plate free to rotate. As a project this is looking complicated and expensive. A second caliper, second rotor, new master cylinder, all the pipes, fabrications, yaddy-yadda .. :(
Post by Peter Pan » Tue Feb 12, 2019 10:32 am
Checked: the brake tank indicates DOT4 on 2013 Patrol.
