Hard starting '14.
Re: Hard starting '14.
Post by Tomcatfixer » Thu Jan 31, 2019 7:10 pm
Now if someone could just fix the powdercoat...
>AHEM<
Post by eastbloc » Thu Jan 31, 2019 7:16 pm
Update: I have now managed to kickstart, cold, in 15 degree weather, on the fourth kick, after the application of starter fluid into the air box.
'02 Patrol
Post by hotflash44 » Thu Jan 31, 2019 7:32 pm
eastbloc wrote:
Thu Jan 31, 2019 6:11 pm
Yeah, hurray for Soviet Steeds, for sure. It’s been a pleasure problem solving with you guys. Glad I didn’t impulsively but another Ural.
thats a easy fix just a quick repaint all fixed! :boogie: :cheers:
Post by eastbloc » Thu Jan 31, 2019 10:54 pm
Not just repaint -- completely strip and repaint. Which is probably going to be a lot more expensive than sourcing used bodywork as things rot.
'02 Patrol
Post by Tomcatfixer » Fri Feb 01, 2019 5:43 am
Again, I suggest...
Post by eastbloc » Fri Feb 01, 2019 8:10 am
Again, I suggest...
Sure, I get it, and would happily trade the PC for the bedliner. but how does this help with the fact that there’s a layer of rust between the powder coat and the sheet metal?
'02 Patrol
Post by Tomcatfixer » Fri Feb 01, 2019 8:39 am
I'm not saying it will be cheap or easy, but there ARE solutions that will all but guarantee you won't have the same thing happen again.
Post by eastbloc » Fri Feb 01, 2019 9:18 am
Final update on the hard starting saga. This morning, it is 12oF, and the motor is stone cold, hasn't been run in over 14 hours. A spray and four or five kicks and it comes to life. Almost as easily as the 650.
To me, this means the starter can once again become a totally obsolete accessory despite the fuel injection, resolving my most significant objection to my '14. While I do want this trick to work without a spray can, had we come up with this prior to my futzing around with Taiwanese starters and car batteries, I probably would have skipped all that.
Thank you everyone for helping me wrack my brains on this one, and to Chad in particular for his "simplified starter fluid tek." It's nice to feel reassured that there is always a rational explanation for everything, even when there's a damned computer (or two) in the middle of the thing :)
'02 Patrol
Post by Tomcatfixer » Fri Feb 01, 2019 9:23 am
Bah! I think someone else suggested trying the starting fluid. I just found an easy way to squirt it into the airbox. :cheers:
Post by eastbloc » Fri Feb 01, 2019 10:06 am
Yes, thanks also to Barry for pioneering the technique :) it takes a village, and I’m happy to be the idiot of this one.
I do still wonder what it is that makes some FI Urals more cold-blooded than others.
By the way, I did discover today that it is easy to overdo it with the starter fluid, in which case you will need to rev it a little bit to clear it out or it will run like garbage and possibly foul the plugs. A quick, split-second spray is all that you need.
'02 Patrol
Post by Mr Wazzock » Fri Feb 01, 2019 10:07 am
:boogie:
Post by windmill » Fri Feb 01, 2019 10:57 am
Starting fluid and fuel in the intake for cold weather starting has been around a lot longer than I have, I'm just another one of the idiots to forget the simplest solution, and over think it......... :foilhead:
Post by Mr Wazzock » Fri Feb 01, 2019 11:19 am
Village idiot joke: (imagine the following said in country yokel dialect): "Wha's that you got thar then?" - "This? This is moi front door." - "What you carryin' that around for then?" - "Lost the key hav'n' oi?"
Post by hotflash44 » Fri Feb 01, 2019 12:41 pm
Man thats the worse Hillbilly accent i ever seen written :boogie: :boogie:
Post by Mr Wazzock » Fri Feb 01, 2019 12:46 pm
Not supposed to be hillbilly, so I guess it was Image
