Extra plug found
Papa mike
Extra plug found
Post by Papa mike » Tue Feb 13, 2018 8:11 pm
While putting on shinguards found unplugged 2 wire female, appears to go to hack. Also at 45 mph get spitting and farting til 50mph . Just started today, 250 miles on new 2017 m70. Was running good last ride.
2017 m70, 2002 hd,69 Manx, spec const vw trike. 67, riden sickles since I was 10.
Life is hard, it's harder for those who are on my bad side. :lol:
BillyG
Thread Killer
Thread Killer
Re: Extra plug found
Post by BillyG » Tue Feb 13, 2018 8:59 pm
Horn.
Bill Glaser
2002 Ural Patrol "CYKA"
Penrod
Post by Penrod » Tue Feb 13, 2018 9:46 pm
When my 2015 cT was new there were times when it would spit and sputter. Eventually, ot stopped. Perhaps the map needs to be updated at the dealers.
Live in Maine. Retired.
Papa mike
Post by Papa mike » Tue Feb 13, 2018 10:01 pm
Supposed to have or map installed. Just started farting today. Not sure if I unplugged something but female plug goes to hack.
Post by windmill » Tue Feb 13, 2018 10:22 pm
It started farting, and you found an unplugged connector after installing leg guards? Maybe something else like a sparkplug wire is loose too.
Papa mike
Post by Papa mike » Wed Feb 14, 2018 2:29 am
Thanks guys, I will look again in the morning. Don't believe in such obvious co incidences. I figure now it must have been caused by me.
Post by windmill » Wed Feb 14, 2018 2:56 am
Papa mike wrote:Thanks guys, I will look again in the morning. Don't believe in such obvious co incidences. I figure now it must have been caused by me.
One time I had an intermittent power loss on my Patrol. After much frustration it occurred to me that it started right after putting the windscreen back on. Turns out I pinched the wire from the right handlebar switch with the mounting clamp which was causing an intermittent short of the kill switch.
Post by hotflash44 » Wed Feb 14, 2018 9:19 am
Papa mike ,yeah worth a look, old school saying is if the machine started working different right after you work on it, its probably somewhere in that area to start looking. good luck! :cheers:
Post by Speedbump » Wed Feb 14, 2018 9:36 am
Right side O2 sensor wires?
Glen³
1977 GS550
1979 XS750
Beastmaster
Post by Beastmaster » Wed Feb 14, 2018 11:08 am
When I received my bike and was looking it over with the dealer I found a double female connector unplugged. It is located on the right side, forward and above the right cylinder and I asked what it was for and was told "don't worry about it". I always hate answers like that so I pressed him and was told it is a diagnostic port. Not sure if yours might be the same or if its related to your maintenance.
Post by gobium » Wed Feb 14, 2018 11:35 am
Beastmaster wrote:When I received my bike and was looking it over with the dealer I found a double female connector unplugged. It is located on the right side, forward and above the right cylinder and I asked what it was for and was told "don't worry about it". I always hate answers like that so I pressed him and was told it is a diagnostic port. Not sure if yours might be the same or if its related to your maintenance.
I guess on 2017 imwa moved the DP to right side with 2 wires.
My 2015 is 6 wires and located behide the left cover
Post by windmill » Wed Feb 14, 2018 11:41 am
I think that dealer is smoking crack, the data port on my 2018 M70 is a 4 wire connector in the headlight shell.
Post by gobium » Wed Feb 14, 2018 11:43 am
Correction on my post my DP is 4 wires
Post by Albuquralque » Wed Feb 14, 2018 11:49 am
Maybe a pic of said 2-wire (double female) connector might help. I have serious doubts it is a "diagnostic" port for something.
Post by gobium » Wed Feb 14, 2018 11:52 am
I think the 2 wires might for this side pannel
Wire is not hot becuase inline fuse removed.
