Mixed up drain plugs
robtjm
Post by robtjm » Thu Mar 10, 2016 3:29 pm
I drained the oil from the engine and transmission of my '07 Patrol, and managed to mix up the two drain plugs. Can anyone tell which is for the engine and which is for the transmission? Photo attached. Thanks.
2007 Ural Patrol
robtjm
Re: Mixed up drain plugs
Post by robtjm » Thu Mar 10, 2016 3:35 pm
My photo of the two drain plugs doesn't appear to have posted in my original inquiry.
2007 Ural Patrol
GillaFunk
Post by GillaFunk » Thu Mar 10, 2016 4:21 pm
Based on this:
http://www.sovietsteeds.com/forums/view ... hp?t=30736
left to right, Dipstick, FD, Trans Drain, Trans Fill, Engine Drain.
:shock: :o They all look the same
Sgt. USMC 0311, 8156
Post by chaos2 » Thu Mar 10, 2016 5:58 pm
The one with the longer magnet may be an aftermarket unit. FWIW, on mine the transmission fill and rear end tend to pick up the most fuzz once everything was broken in.
robtjm
Post by robtjm » Fri Mar 11, 2016 10:02 am
Thanks very much guys. Very helpful. Oil goes in today.
2007 Ural Patrol
shiftless
Post by shiftless » Fri Mar 11, 2016 10:48 am
Thread tape.
Still like Charlie Chaplin's 1940 talkie "The Great Dictator"; had to abandon it as the inspiration for the theme of my Ural's paint scheme. People can't seem to tell satire from support. Too much public education.
http://en.wikipedia.org/wiki/The_Great_Dictator
2011 Gear Up from V.T. CYCLES, Pwr Arc Ignition, sprayed USMC 383 Green w/blacked engine/exhaust
daydream
Post by daydream » Tue Mar 15, 2016 5:39 am
I put a nitrile O ring on all my plugs - no leaks.
07 Ural Patrol Русский кусок дерьма
10 Triumph Bonneville
06 BMW R1200RT with Hannigan Sidecar
Post by GHGoodwin » Tue Mar 15, 2016 7:37 am
This belongs Hammerin thread.
