Final Drive-Driveshaft Clunk
- Mr Wazzock
- Contact:
Re: Final Drive-Driveshaft Clunk
Watching the video several times, pretty sure it's every wheel rotation.
- New Member
Donut is fine. Attempted to reverse out of garage to load on trailer and it would not go into gear and emitted a very loud grinding noise. At one full tire rotation it clanks and shudders in the same place. She’s going to dealer, the gasoline can and matches are too near at hand right now and too much on my plate.
NW Arkansas...back-road mecca.
2015 Ural Gear up
2016 BMW S1000XR
2015 Ural Gear up
2016 BMW S1000XR
If it's the same as a 2012 the adjusting nut (the one holding the wheel on the axle) is under the hub capon the sidecar - but that sound on your video is way,way,WAY louder than anything on my rig,got to be something else.
I'm a Marxist at heart-you can't beat Groucho,Chico,and Harpo!
2012 Patrol T
2012 Patrol T
Since your first post was just 2 days ago and you said you just picked the bike up can you go back to the seller or dealer. It's too inconvenient for that to happen right away and I'm unsure if the missing FD bolt (and the other loose one) contributed to the issue. It certainly didn't help.
So sorry to read this.
- Mr Wazzock
- Contact:
I'm thinking broken tooth on the ring gear.
- New Member
Three broken teeth and lots of metal flying around. Dealer quoted $2200 complete parts and labor for a replacement but just found out that drive is backordered until 21 Nov.
If I can find a unit faster I will do it myself, saving money and hopefully some time.
Welcome advice on a reliable source for parts.
2015 Ural Gear up
2016 BMW S1000XR
2015 Ural Gear up
2016 BMW S1000XR
- Comrade General
I think Mr. Wazzock is due his customary fee for diagnostics
Seriously, very sorry to hear of such troubles with a recently-purchased machine. I hope you have some recourse with the seller.
1982 BMW R100T
1994 BMW K75RT
1995 BMW K75/3
2009 Kawasaki KLR 650
2017 Harley-Davidson Road King
2017 Harley-Davidson Road Glide Ultra
2017 Honda CB1100EX
2020 Ural Gear Up
1994 BMW K75RT
1995 BMW K75/3
2017 Honda CB1100EX
2020 Ural Gear Up
- Desantnik-VDV
- Order of Lenin
You may try contacting Randy mailto:randy@uniqueridesco.com for his closeout sale:
viewtopic.php?f=13&p=740745#p740434
Gene Langford at Holopaw https://uralofholopaw.com/
Terry Crawford http://www.crawfordsales.info/
All three of them are in similar distance from you. They might have it in stock and could ship it sooner.
Alex
2007 GearUp - BMD (https://en.wikipedia.org/wiki/BMP-3)
40/130
The rest is just history... 4 previous Urals, BMW airheads, bigger Hondas, bigger sidecars...
40/130
- New Member
Thanks for the references. I will follow up when I get the bike back to my garage.Desantnik-VDV wrote: ↑Wed Oct 28, 2020 7:27 pmYou may try contacting Randy mailto:randy@uniqueridesco.com for his closeout sale:
2015 Ural Gear up
2016 BMW S1000XR
2015 Ural Gear up
2016 BMW S1000XR
You said you have a shop. Depending on your mechanical skills and/or ambition, you can rebuild the FD yourself for well under ~$800 (haven't priced the parts recently, but that's close). The job is well-documented step-by-step at BillyG's myural. com and on a number of threads here on SS.
$2200 sounds steep, but then they're charging hourly rates on labor at shop time. It probably breaks out to $1000 parts plus markup and $1200 labor.
Do it yourself and pay yourself $1200+. Take the wife out to dinner on the Ural and smile.
- Mr Wazzock
- Contact:
$2,200 does sound too much to me.
- Mr Wazzock
- Contact:
- -cookiemech wrote: ↑Wed Oct 28, 2020 3:45 pmI think Mr. Wazzock is due his customary fee for diagnostics![]()
(No but not ALL the time
I looked on the reimbursement sheet for dealers and Ural allows 2.8 hours for complete removal, disassembly, reassembly, and installation of the 2WD FD. That's from an old sheet from 2005 - it may have changed, but probably not by much. I'd put money down that even Van can't do it in 2.8 hours, and that presumes having all the parts on hand. (Watch - Van's gonna read this and try to see if he can beat it). When we were out in Redmond Van disassembled a hydrolocked engine in under 40 minutes with Sergei watching.
I don't think any normal human even with skills can do the job that fast. Maybe Sergei, but then all he works on is Urals and for years now. The problem Ural owners have with most dealers is that the dealers don't do enough Ural work to get good at it, plus mechanics notoriously move on to somewhere else. I'm exempting the dealers like Gene, Terry, Heindl, Ski, Ural NE, etc who sell and service a lot of Urals. I'd estimate 4 hours, and again that's having all the replacement parts on hand.
So depending on your dealer's shop rate, he's hitting you up for 8-10 hours of shop time. No sin, but I think he's learning on your bike.
- BinDerSmokDat
I'm late to the party but I know a thing of 3 about breaking FD's....
A clunk every wheel rotation and/or wheel not spinning has been a ring gear in my experience.
Quickest check, pull FD plug, if there is metal exceeding normal swarf, you got a problem.
STOP riding and get it trailered, you can F-up the case by continuing to ride. There is little free space in there and the chunks of ring gear can get caught between carrier and case . Steel gear teeth vs. aluminum case = case loses.
You probably had a tooth break and that caused the rest of your issues.
Of my 3 FD failures, twice it was a broken tooth on the ring gear.
The third was a combination of pinion nut not seated correctly and/or pinion bearing failure, kind of a chicken/egg thing, not sure what happened.
The ring gear was chewed up pretty bad, no completely broken teeth but some big chunks.
I tightened the pinion nut down, flushed FD and it survived a long hard weekend of off-roading in the rocks.
I rebuilt TWO FD's recently and it was around $700 in parts, replacing almost all bearings, seals, ring gear bolts, some internal spacers AND two ring and pinion sets. Both were built out to new/better than new spec for that case design. A few of the seals and bearings were actually upgrades over stock (better seal material, better class of bearing.) That price even included bags of hardware with some left over for future uses, ring bolts, new Nylok nuts for the newer case, new ring bolts, new nuts and split washers for the older case.
Get the FD apart, check out BIlly G's site, my FD thread and call Terry Crawford.
If you have a vice, patience and a little mechanical skill, it's not that hard.
The biggest issue is usually backing out the ring gear bolts, hence why you need a vice and possibly a little heat.
The vice is also handy for holding parts while you tap bearings and seals in place.
Last edited by BinDerSmokDat on Fri Oct 30, 2020 11:23 am, edited 5 times in total.
- BinDerSmokDat
Billy G's page has nice pics of the order, techniques and tools.
My thread has additional close-ups, internal parts changes over the years, etc.
I wouldn't have attempted my 1st rebuild without Billy G's page.
viewtopic.php?f=5&t=30207
http://myural.com/final_drive_disassembly_with_2wd.htm
