Which Red Line in tranny?
Post by chaos2 » Fri Oct 07, 2016 10:23 pm
is there a consensus among those who use Redline oils which variety works best in the Ural transmission? I have a quart of Heavy Shockproof I'm thinking of using next instead of the Mobil 1 V-twin 20-50, which works great. Just wondering if the Redline would work better. Their website lists a V-Twin transmission oil that sounds custom made for Urals "This product dampens transmission noise (reducing the notorious shifting clunk found in these gearboxes)" then later "Same fluid as our unique Heavy ShockProof® Gear Oil" I had some jumping out of gear issues with Castrol 20-50 and 90wt gear oil that the Mobil V-twin 20-50 greatly reduced. I almost hate to try something else but am curious about the Redline.
past afflictions include limey motocars and bikes, R60/2, R65ls, and a Citroen.
Now an 87 K75s, DB Haanjo gravel bike, a DB hardtail mtn bike, and a rusty 2012 GU bought new
Raceway needles, Modtop exhaust
Re: Which Red Line in tranny?
Post by GHGoodwin » Sat Oct 08, 2016 7:49 am
I use Redline in both my bikes. Go with the straight HD Shockproof. I believe the V-Twin oil is for wet clutches.
The jumping out is not related to the oil. You might need to adjust your neutral.
lomax
Post by lomax » Sat Oct 08, 2016 10:32 am
I use this in the trans: https://www.amazon.com/gp/product/B000C ... UTF8&psc=1
And this in the final drive: https://www.amazon.com/Red-Line-58204-S ... dline+gear
So far so good, no leaks, no fuzz on the drain plugs.
Marc
84 R100RS LE,14 Ducati MTSGT,14 Hyperstrada, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR, 01 200EXC, 77 HD XLCR, 15 Enfield Classic. https://lomaxcm.smugmug.com/
lendrinkard
Post by lendrinkard » Sat Oct 08, 2016 12:49 pm
Joe I used both the HD Redline and the lightweight Redline. Like the HD better. I now us Moble 15-50 synthetic with good results.
2012 Gear up
130/40 jet, 3 shims, no mid-pipe, drilled slider, 2013 Branch pipes, LED running lights
Post by chaos2 » Sat Oct 08, 2016 1:49 pm
Thanks. I'll try the HD and report back
lsiemasko
Post by lsiemasko » Sat Oct 08, 2016 7:30 pm
HD Shock in both GB and FD.
You will notice a definite change in shifting on the GB after about 1K km.
No need to change it every sunrise once you have broken in the gears (~ 10K km)
Changed mine out at that to check the swarf, NONE.
This is NOT about saving a few $$$, but superior lubrication and protection.
Larry S.
03 Tourist for me and the wife - Wehrmacht Style
02 Bavarian Classic (Custom Tub) for Walter,Peyton, Ellie May, Loki, and Jett, my mastiff monkeys!
03 Dyna Glide (Surface dust created by excessive use of the Urals)
03 Sportster 1200C - Wife's Ride (Unfortunately NO trunk for "stuff")
DesertRat
Post by DesertRat » Mon Oct 10, 2016 9:25 pm
lomax wrote:I use this in the trans: https://www.amazon.com/gp/product/B000C ... UTF8&psc=1
Marc
This is what I use too, and no problems with it.
2009 Sahara
Slides drilled, 2 shims, Yamaha petcock.
sean026's steering damper (the best modification ever!)
Post by chaos2 » Tue Oct 11, 2016 1:12 am
They also make several manual transmission oils for cars, and the Vtwin trans oil that is similar to the HD shock. Wondering what the advantages of the HD or Lightweight are.
Post by gobium » Tue Oct 11, 2016 1:18 am
Add little saw dust or banana peels to transmission oil
Post by chaos2 » Tue Oct 11, 2016 9:35 am
gobium wrote:Add little saw dust or banana peels to transmission oil
What kind of sawdust? Pine, Oak, Ash? (got lots of ash thanks to the emerald ash borer) We need to know!!!
lsiemasko
Post by lsiemasko » Tue Oct 11, 2016 1:40 pm
Van,
that is one of the first tricks you learn when you can't afford to fix that screaming GB or rear axle.
actually, I put sawdust in my first car when it was really making noise, never had a problem with it from there on out.
simple things sometimes work better.
Larry S.
thecount043
Post by thecount043 » Mon Oct 31, 2016 2:11 pm
Marc
I used these lubricants also, but I switched them around with the lightweight in the final drive and the heavy duty in the transmission. I imagine anyone of them could be used in both units. Has anyone given any guidance on their use?
2011 Ural Retro "Ludmilla"
2010 Royal Enfield Bullet "The Nina"
1994 Honda Goldwing SE "The Gold Wing"
Pootierider
Post by Pootierider » Sun Mar 05, 2017 9:22 pm
Which is better in the transmission: heavy duty or lightweight? It seems like a lighter weight would make sense, since the gearbox runs cooler, and the factory recommendation is for 20w50 motor oil. But most on this list seem to go with the heavy duty....
Pootierider
Post by Pootierider » Sun Mar 05, 2017 9:46 pm
Also, if you look at Redline's website, it looks like HD Shockproof is for differentials and LW Shockproof is for manual transmissions. So, again, doesn't lightweight shockproof make more sense for the tranny?
Pootierider
Post by Pootierider » Mon Mar 06, 2017 12:04 pm
On the other hand redline vtwin trans fluid is the same fluid as heavy duty shockproof, not lightweight shockproof.
