center stand mods?
ReCycled
Re: center stand mods?
Post by ReCycled » Sun Aug 26, 2012 4:22 pm
Thermos wrote:I just changed out rear tires using the 2 by 4 method, and it works so easy! I was able to remove my continental knobby tire(super aggressive tread) very easy with the extra clearance!. Thanks ReCycled!
-T
Just passin' the tried and proven methods. OK truth be told, I was taught to use a 2x4 and a brick but I thought there was room for improvement :D
David B.
'07 Ural Twourist
Ivan Rider
Post by Ivan Rider » Sun Aug 26, 2012 7:02 pm
ReCycled wrote:I like putting a 2"x4" under the inside leg of the centerstand whenever I plan to pull the rear wheel. The extra height and space just makes the process easier, especially if a knobby is involved.
Getting the bike on the centerstand is difficult enough when the rear is flat, the extra 1 1/2" makes it nearly impossible. In addition the first piece of 2x4, I also carry two more pieces screwed together to make it 3" thick. I first roll the back tire on to the single 2x4 and then the double. Now that the back of the bike is raised, I place the single 2x4 under the inside leg of centerstand and roll the bike back. The additional 1 1/2" mechanical advantage means it pops right on to the centerstand without any effort.
To space save, these pieces need only be 4"-6" long. But I prefer the doubled piece to be longer and can then be used as a sturdy prop to hold the front wheel high off the ground when the centerstand is deployed as described and the rig is sitting on the two rear wheels.
That's the way I've been doing it for years. I call my 2x4 my "Ural Jack"
Ivan Rider AKA: Dennis
http://www.flickr.com/photos/ivanrider/
5 Urals - White 2010 SoloT, White '08 Retro, Blue '05 Troyka & OD '99 Patrol
3 BMWs 2 with Sidecars & 1 Solo
2 Honda Big Ruckus's -1 Solo & 1 w/ Sidecar
berger
center stand mods?
Post by berger » Sun Aug 26, 2012 9:14 pm
I have never had an issue lifting the bike onto the centre stand, even loaded. I do keep some plywood with me to avoid sinking....just have to remember to pull it out!
Another advantage to the inside 2 into 1 is that the centre stand is a breeze to get too.
Sent from my iPhone
Berger
2007 Ural Patrol (1st Owner)
Many, Many Mods.
Ivan Rider
Post by Ivan Rider » Sun Aug 26, 2012 10:26 pm
berger wrote:I have never had an issue lifting the bike onto the centre stand, even loaded. I do keep some plywood with me to avoid sinking....just have to remember to pull it out!
Yep that 2 into 1 does really helps. On my bikes without the 2 into 1 I welded a tang on the kickstant that comes around the muffler for easy access. You can see it in the attached photo if you look close just below the passenger foot peg.
bluesman
Post by bluesman » Tue Mar 15, 2016 12:02 pm
Old thread, but I had a question. How can you change the sidecar tire with the 2x4 method?
2015 Gloss Black Retro Classic
2007 Harley FLSTC, Springer Classic
1942 Harley WLA
Post by Lmo » Tue Mar 15, 2016 3:29 pm
Our friend Van's video helps; scroll over to time index 3:37. Combine his information with the above suggestions.
bluesman
Post by bluesman » Tue Mar 15, 2016 5:24 pm
Awesome thanks!
1942 Harley WLA
Post by GHGoodwin » Tue Mar 15, 2016 5:57 pm
cdscoot wrote:The top plate to a junction box works wonders!
You'll need two.
markhas
Post by markhas » Thu Mar 17, 2016 6:03 pm
Lmo wrote:Our friend Van's video helps; scroll over to time index 3:37. Combine his information with the above suggestions.
Gobium makes us all into block heads with his kiss solutions :)
markhas
AMA member
ABATE Wisconsin
06' Tourist 41167/over 75,000Km, 91" 750 Honda Nighthawk sold to my buddy Ernie, we keep in touch.
Post by Lmo » Thu Mar 17, 2016 7:50 pm
almost disgusting isn't it
