New FDs don't come with bent over taps.
Taps are NO longer available .
Lock taps are one time use, not wise to re use them
Final Drive Issues- Chapter 2
- Msblu79
- Hero of the Soviet Union - 2019
Re: Final Drive Issues- Chapter 2
From what I have seen and experienced the usual failure mode in the FD is the bolt heads shearing off and leaving the threaded stud loctited in the ring gear. Torquing the 10.9 bolts to 24 lb./ft. will stretch and preload the shank and prevent it from moving and developing a fracture under the bolt head.
2010 Black Patrol 90,000km's
Modtop airbox, 2013 branch pipes, Perch rings, Yamaha petcock, Drilled slides, Gossie needles, 145 mains, 45 pilots, insulated manifolds, Modtop pushrods, Dual FMF exhaust, PA Multi-spark system w/ VOES, Spin on filter conversion, 33mpg, Royal Purple fluids.
Yes, from experience. I would not make a statement like that without direct experience. I have seen this on 2 other bikes as well.VWK75S wrote: From experience?
Bolts stretch and loosen.
On 1WD models, (if you check the fluid level often) you will notice the fluid has become silvery. If you attend to the issue at that moment, you will find the fold-over tabs have failed and the bolt heads are rubbing against the outer case. The aluminum particles make the final drive fluid silvery.
Attending to this early, avoids catastrophe.
BTW - these tabs are still available from overseas suppliers.
+1.Msblu79 wrote:From what I have seen and experienced the usual failure mode in the FD is the bolt heads shearing off and leaving the threaded stud loctited in the ring gear. Torquing the 10.9 bolts to 24 lb./ft. will stretch and preload the shank and prevent it from moving and developing a fracture under the bolt head.
Never saw bolts back out, only heads shear off
- VWK75S
Good to know that makes the advice more valuable.propwash wrote:Yes, from experience. I would not make a statement like that without direct experience.
Thanks, John
2009 GearUp 145,000kms
