center stand mods?
center stand mods?
So I went out with the wife to go swimming, and on the way back I got a flat on the pusher. So, I put it on the center stand, go the tire off, and by the time I was to put the spare on, the center stand had sunk into the asphalt about an inch. That made it difficult enough so I had to get out the bottle jack.
Do some folks carry like a metal plate or something else to put beneath the center stand so it won't sink down? Any better ideas?
-T
-T
When you come to the fork in the road, take it!
Yogi Berra
Talent hits a target no one else can hit; Genius hits a target no one else can see.
2011 Orange/Silver Patrol
2017 CRF1000 Africa Twin
1977 R100S
http://tomtomandjoesorangeanviltour.blogspot.com/
http://sovietsteeds.com/forums/viewtopi ... it=Thermos
former bikes-
2001 HD Sportster
1981 Honda CX500 Custom
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
- cdscoot
- Order of Victory
- Location: The lower southern tier of central upstate NY ,Binghamton,NY
Re: center stand mods?
The top plate to a junction box works wonders!Thermos wrote:So I went out with the wife to go swimming, and on the way back I got a flat on the pusher. So, I put it on the center stand, go the tire off, and by the time I was to put the spare on, the center stand had sunk into the asphalt about an inch. That made it difficult enough so I had to get out the bottle jack.
-T
Craig
Experience is a wonderful thing, it enables you to recognize a mistake when you make it again. Every morning is the dawn of a new error .
2010 Patrol T
2016 BMW R1200GS
2010 Patrol T
2016 BMW R1200GS
- a1930ford
- Order of Victory
- cdscoot
- Order of Victory
You could get one of those metal grates for the grill and carry it with you . If you need it under the center stand use it there - if not you are all set for the campfire!
Craig
2010 Patrol T
2016 BMW R1200GS
2010 Patrol T
2016 BMW R1200GS
I took mine off when I removed the mid pipes. The stand hit the mufflers when I moved them up-so I thought- If I build a smaller/lighter jack, I can use it at the old center stand location/under side car/ front @ engine to change any of the tires. I settled on a home made small screw jack that has 5" lift from contact with the center stand pivot shaft. I put the pivot shaft back on after I slid a slightly longer piece of 1/2" claer vinyl tubing over between the side mounts-so te pivot shaft would not rattle. So I lost a few pounds and now have a jack I can use to change any of the (3) wheels. I forgot to add-the base of my little jack is 1/2" thick aluminum that is 2" x 3". So I think it will not push into the ground/asphalt very easily.
1999 victory V-92c Ser # 67
2012 Ural Patrol
20+ bikes and a couple scooters
2012 Ural Patrol
center stand mods?
I don't want to loose the center stand. I find it convenient in most cases. The fact that I needed to get out a jack was aggravating at the time.kawzak wrote:I took mine off when I removed the mid pipes. The stand hit the mufflers when I moved them up-so I thought- If I build a smaller/lighter jack, I can use it at the old center stand location/under side car/ front @ engine to change any of the tires. I settled on a home made small screw jack that has 5" lift from contact with the center stand pivot shaft. I put the pivot shaft back on after I slid a slightly longer piece of 1/2" claer vinyl tubing over between the side mounts-so te pivot shaft would not rattle. So I lost a few pounds and now have a jack I can use to change any of the (3) wheels. I forgot to add-the base of my little jack is 1/2" thick aluminum that is 2" x 3". So I think it will not push into the ground/asphalt very easily.
-T
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
center stand mods?
I like the idea of the magnetic metal bowls!!a1930ford wrote:Squished up beer can or soda can works in a pinch. I'd bet that if you had a couple of those mechanic metal bowls with magnets on the bottom, like you can get at Harbor Freight or an any auto store, you could easily attach them inside the walls of the trunk and use them for such just such an event or as dog bowls for water. Actually lots of various uses when you get creative. They don't take up any real space and hang in there ready for use. I haven't done this to make sure it works, but I am betting it would.
-T
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
- ReCycled
- Hero of the Soviet Union - 2019
I like putting a 2"x4" under the inside leg of the centerstand whenever I plan to pull the rear wheel. The extra height and space just makes the process easier, especially if a knobby is involved.
Getting the bike on the centerstand is difficult enough when the rear is flat, the extra 1 1/2" makes it nearly impossible. In addition the first piece of 2x4, I also carry two more pieces screwed together to make it 3" thick. I first roll the back tire on to the single 2x4 and then the double. Now that the back of the bike is raised, I place the single 2x4 under the inside leg of centerstand and roll the bike back. The additional 1 1/2" mechanical advantage means it pops right on to the centerstand without any effort.
To space save, these pieces need only be 4"-6" long. But I prefer the doubled piece to be longer and can then be used as a sturdy prop to hold the front wheel high off the ground when the centerstand is deployed as described and the rig is sitting on the two rear wheels.
David B.
'07 Ural Twourist
'07 Ural Twourist
- pjarmstrongaz
- Comrade General
a scooter shop I used to go to had giveaway kiktsand platorms. These were made o plasti so I'm not sure they would be hardy ehough or the Ural. But maybe your loal bike shop has these.
Pam
2007 Gear Up "SHREK"
2012 CSC Military 150 Camo
If nothing else, go to a Metal Fabrication shop. have them cut you a 4" x 10" x 1/8" thick piece of aluminum. Round off the corners. Drill (1) small hole near a corner so you can run a bright colored piece of nylon string. loop the string over the handle bar. That way you don't have to crawl under the bike to get it-and the colored string will remind you it is there. Plus it weighs almost nothing.
2012 Ural Patrol
2012 Ural Patrol
You must have taught me that, 'cause that's exactly what I have and use.ReCycled wrote:I like putting a 2"x4" under the inside leg of the centerstand whenever I plan to pull the rear wheel. The extra height and space just makes the process easier, especially if a knobby is involved.
Scott
2004 Ural Patrol
"You can ride farther in one hour than you can walk in a day"
"Media bias contributes to erosion of the perception of truth." Tanya Marcum
2004 Ural Patrol
You wouldn't have any pictures of this process, would you?ReCycled wrote:I like putting a 2"x4" under the inside leg of the centerstand whenever I plan to pull the rear wheel. The extra height and space just makes the process easier, especially if a knobby is involved.
-T
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
- ReCycled
-T
The doubled piece was cut to fit the width of the trunk, any shorter and I would worry about rolling off the back before the centerstand was fully deployed. The single can be smaller but again, a larger target makes it easier. Line up the single then double behind the rear tire. Roll the bike back. Line up the single under the centerstand. Pulling up/back on centerstand should be a little easier as you now have an 1 1/2" advantage. Look at how much ground clearance is gained, this makes servicing easier. Now the double is free to prop the front of the bike for front end service.
After I packed things back in the trunk I did it again as I realized this was an opportunity to mention an important safety practice. Whenever you place the bike on the centerstand and remove the rear wheel there is a serious risk of damage or injury should the bike roll forward. This may be because of the slope, footing, or simply because you are wrestling with something to fit. A very easy and secure way to prevent this is to run a strap between the front wheel and the indside leg of the centerstand.
David B.
'07 Ural Twourist
'07 Ural Twourist
-T
Thank you for taking the time to post this info with pictures! That is so simple, I will do just that this afternoon when I switch out tires.
Awesome-
-T
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
I just changed out rear tires using the 2 by 4 method, and it works so easy! I was able to remove my continental knobby tire(super aggressive tread) very easy with the extra clearance!. Thanks ReCycled!
-T
-T
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
