Oil Change Warm or Cold
kevinkrenik
Post by kevinkrenik » Tue May 02, 2017 10:29 am
Never understood oil change while its "warmed up".
-Should be thinner when its cold?
-Most of the oil should be bottom-dead-center....
-If you warm it up you re-coat the entire engine and fill up passages, so less will drain out in "X" minutes...
-Oil should be macro-"mixed" due to previous running, obviously isolated deposits in valve cover case, filter, lines, may have settled or be non-isotropic...but the overall contaminate PPM should be consistent.
2015 M70
2005 Honda VTX 1300C
Minnesota, USA. (2017 Ural Newbie)
Bilgekeeldave
Re: Oil Change Warm or Cold
Post by Bilgekeeldave » Tue May 02, 2017 10:52 am
I change my oil when it's cold also. I just let it drain until it stops dripping.
Dave
RAMCO-Dnepr MT-16
Post by Tomcatfixer » Tue May 02, 2017 11:31 am
I was always under the impression that oil changes should be done immediately after engine shutdown because the contaminants are still suspended in the oil; they haven't had time for gravity to pull them down to "stick" to the pan.
Virginia Beach, Virginia, USA
Post by Lokiboy » Tue May 02, 2017 11:34 am
Tomcatfixer wrote:I was always under the impression that oil changes should be done immediately after engine shutdown because the contaminants are still suspended in the oil; they haven't had time for gravity to pull them down to "stick" to the pan.
+1.
I don't ride around until it's hot, but I'll do a 1/2 mile ride to warm it up
70,000 km and counting
Post by chaos2 » Tue May 02, 2017 11:50 am
Warm or hot. Easier to scald you fingers of if you're really stupid grab the exhaust header for those manly "oil change scars"
Raceway needles
Modtop exhaust
Post by rougaroo » Tue May 02, 2017 12:25 pm
Geezer knowledge (and dinosaur alert): there once was a time when oils were "non-detergent". Particles settled out of ND oil and remained in the sump. It is still basically a good idea to use ND to break in an engine for the first 500 miles or so, so the metal fines drop out of solution easily. Detergent oils keep particles in solution and circulating in the oil.
So the idea was - as I understand it - that after break-in you should drain ND oil while hot so you get any particles before they settle out. With modern detergent oil, I don't think it makes any difference.
Post by rivers » Tue May 02, 2017 1:11 pm
You want to change oil when hot while all the crap/crud is still in suspension and flows out with the oil. Giving the crud time to settle out into the bottom of the oil pan gains you nothing and just prematurely dirties you new oil.
Post by stagewex » Tue May 02, 2017 4:13 pm
Hot/Warm always if you really want to get all the old oil out.
GewehrRides1
Post by GewehrRides1 » Tue May 02, 2017 4:35 pm
I ride mine for a few miles, drain, and leave everything open overnight so I get every last dirty, ugly, crappy drop. Same with trans and final drive.
On day two, I wipe the oil off the floor because some dumb $#!+ kicked the drain pan out of place before going upstairs.
Ron, Brigitte, and Gewehr
Midway, NC
sixbennetts
Post by sixbennetts » Tue May 02, 2017 8:41 pm
Chocolate milk is better when you shake it first. Mixes up all the chocolate in the bottom.
That's why I ride it a bit before an oil change. To get the chocolate out.
I have a funny wife. Hilarious, really.
I love her, she loves me.
______________________________________
2007 Ural Retro, "Подарок солдата солдату"
"I'm slow and like to go old."
Plattsburgh NY
Tin Man
Post by Tin Man » Tue May 02, 2017 10:35 pm
sixbennetts wrote:Chocolate milk is better when you shake it first. Mixes up all the chocolate in the bottom.
.........this.......
2007 GearUp (Arctic #1)
Post by Wildhorse Cafe » Fri May 05, 2017 11:41 am
20/50 wt. would be more viscous when cold. :idea:
kevinkrenik
Post by kevinkrenik » Mon May 08, 2017 4:25 pm
Wildhorse Cafe wrote:20/50 wt. would be more viscous when cold. :idea:
20w=20 winter...big numbers are thick oil...It's why southern states can get away with straight weight oil.
2015 M70
Bilgekeeldave
Post by Bilgekeeldave » Mon May 08, 2017 9:30 pm
The W stands for weight, not winter.
Dave
RAMCO-Dnepr MT-16
Post by Tomcatfixer » Tue May 09, 2017 4:50 am
Oil manufacturer Valvoline seems to think it stands for 'winter': http://www.valvoline.com/about-us/faq/o ... cosity-faq
The Pep Boys break it down even further explaining that there are only six winter blends (I didn't know that): https://m.pepboys.com/accessories/car_c ... rn_weights
