g-414 dynamo revival ?
rune2650
Post by rune2650 » Thu Jan 30, 2020 7:21 pm
so, my Dnepr k750 stoped charging the battery, the electronic charging relay from jan-buchwald.dk isn't something I can figure out how to see if it still works, but the dynamo is what that's confuses me.
i have had it pulled apart, cleaned the brushes, cleaned the contacts on the commutator, checked it for shorts, checked the windings for any shorts or brakeges and resolderes them back in there exact locations that they where in before, checked the field winding, and everything checks out fine.
i even tried to "flash" the generator, and no mater what I do, I can only get 0.15v DC when spinning the dam thing at 750rpm (like in this video: https://www.youtube....h?v=7n8gZ4cyesw )
what is it that im doing wrong ? or perhaps might have overlooked
Re: g-414 dynamo revival ?
Post by jaybird » Mon Feb 10, 2020 3:20 am
Bump.
cateyetech
Post by cateyetech » Mon Feb 10, 2020 7:49 am
Hey rune
I don't know your exact generator
but on the old bikes I work on
a shorted armature is common
and needs to be checked with a growler
to tell if it shorted out
It sounds like you have covered everything else
Good luck :foilhead:
rune2650
Post by rune2650 » Mon Mar 09, 2020 7:25 am
I finally managed to get the dynamo to work again, it turned out to be one of the coals that didn't deliver power correctly, it seemed to be where the wire was inserted into the coal, but after changing that, I got around 4.3V DC out of the dynamo, when spinning it at 750rpm, and after I paired it with a new used mechanical voltage regulator (original model for my bike, PP302), the bike charges the battery with no problem :D
