Broken Sidecar Frame
cookiemech
Post by cookiemech » Thu Jan 16, 2020 12:37 pm
I'm glad my friend Ed stopped over this morning for coffee. As usual, we repaired to my garage afterward since he likes to see what I've done since his last visit. I pulled the Ural out from its spot next to the BMW R100 I've been working on, so he could see the R100. For some reason, as I stood talking with him, I shook the left handlebar on the Ural, and noted that the sidecar was bobbing up and down, which I would not expect. This is the reason:
Geez! Two days ago I had it out for a nice 70 mile drive and certainly hit speeds of 55 to 60 mph. That could have gone very badly, I think.
I know it wasn't broken a week ago when i flushed and bled brake fluid all around, as I was under there.
Anyone have experience with this particular failure? This machine has never been off road or subjected to anything unusual, and has roughly 8000 miles on it. My friend Chuckie, a master welder with 45 years experience, is stopping over tomorrow to see it.
2014 Ural Gear-Up
Re: Broken Sidecar Frame
Post by Snakeoil » Thu Jan 16, 2020 12:51 pm
:lurker:
Post by chaos2 » Thu Jan 16, 2020 3:12 pm
Albuquralque had a 2014 where the snowman mounts broke off the frame, but the frame remained intact.
Post by Mr Wazzock » Thu Jan 16, 2020 3:21 pm
Feck! :o
Post by Wildhorse Cafe » Thu Jan 16, 2020 4:04 pm
Wow! How are your welding skills?
cookiemech
Post by cookiemech » Thu Jan 16, 2020 4:07 pm
I am confident about my welding skills so long as the piece isn't "mission critical". (I've done lots of autobody work and built cars for nieces from wrecks.) However, my friend Chuck is coming over tomorrow morning to look at it. Chuck has been a welder for a living for the past 45 years. I TRUST Chuck's work!
2014 Ural Gear-Up
Post by Tomcatfixer » Thu Jan 16, 2020 4:35 pm
That is an impressive failure, the likes of which I have not yet seen! Looking forward to seeing images of the repair.
Post by stagewex » Thu Jan 16, 2020 4:38 pm
Never saw anything break like that and you say you don't ride off-road? That's certainly a good thing!
2006 Honda "Big Ruckus" PS250
ReCycled
Post by ReCycled » Thu Jan 16, 2020 4:39 pm
That's a new one to me.
At first glance I thought it was going to be the snowman mounts, a known failure point... might as well have Chuck look at them too :)
David B.
'07 Ural Twourist
cookiemech
Post by cookiemech » Thu Jan 16, 2020 4:41 pm
Yes, Chad, I am as well. My concern is that if it happened at this spot, will it happen elsewhere? I didn't have any "event" that should have caused this, no significant pothole (no bent rim or blown tire).
Note that during the winter of 2018/2019, I had EVERY nut, bolt, fastener off this machine and EVERY painted piece was media blasted, shot with epoxy primer and single stage urethane, and I put it back together. So geez, not like each piece hasn't been handled and examined . . .
I'm the wrong kind of engineer here (electrical, not metallurgical) to understand this failure. Maybe the three cracked aluminum rims should have been some sort of clue?
2014 Ural Gear-Up
cookiemech
Post by cookiemech » Thu Jan 16, 2020 4:42 pm
"Snowman mounts"? Are those the welded-on points with knobs on them that are part of the motorcycle frame?
2014 Ural Gear-Up
Post by sKiZo » Thu Jan 16, 2020 7:12 pm
"Snowman" refers to the rubber cones that soak up shocks to the car body.
And yes, I'd call that "mission critical" and leave the fix up to a pro, and add additional strengthening with both inner and outer tube reinforcements. Lots of rust evident inside the broken tube too, so I'd do some serious digging to find out how water was getting inside.
And ya, I'd worry about the rest of the frame too. Bad batch of steel? I'd give the whole sidecar a close inspection, and hope for the best.
Post by harryball » Thu Jan 16, 2020 7:34 pm
Just wow. Something new to be paranoid about.
Post by jeffsaline » Thu Jan 16, 2020 8:42 pm
My long distance guess is the failure is from the assembly welds and is in the heat affected zone (HAZ) of those welds.
I'll venture if I was fixing this frame I would probably put a piece on the inside of the frame for alignment and strength. After that was in and welded I would probably add a piece to the outside of the frame on at least two sides.
Maybe consider buying a lottery ticket as it seems you got lucky with this.
cookiemech
Post by cookiemech » Thu Jan 16, 2020 8:55 pm
I will mention this to my welder friend tomorrow. Thanks!
2014 Ural Gear-Up
