Final Drive Gear Oil Volume Discrepancy 2007-2008
Post by Desantnik-VDV » Fri Dec 06, 2019 6:45 pm
I remember 1999 and 2002 models final drive had 3.5 oz or 105 mL volume, while 2WD Gear Up and Patrol later years had 4.5 oz or 135 mL.
Now for first time I am changing gear oil on a 2WD Ural (2007 Gear up). Measured with postal scale exactly 4.5 oz and filled the final drive and it shows about 1/2 inch above the full line on the dipstick (screwed in). I doubt bit there might be some of old oil leftover (undrained).
There is a mistake/discrepancy in 2007 and 2008 manuals. 3.5 oz = 105mL and 4.5 oz must be 135 ml.
2007 GearUp NOS
The rest is just a History:
2014 Ural M70
2002 Ural Barberian Classic
2003 Honda Shadow ACE
Re: Final Drive Gear Oil Volume Discrepancy 2007-2008
Post by wooden nickel » Fri Dec 06, 2019 8:09 pm
I don't know how much it will throw you off but since oil is a lower specific gravity than water, the oil volume will be greater than the fluid ounces for water.
I use a basting syringe to get the proper fluid ounces, not weight.
Post by chaos2 » Fri Dec 06, 2019 8:24 pm
I noticed that little discrepancy in my manual too :lol: I usually overfill mine a bit and let the excess blow out the vent until it finds it's happy level (the lower line on the dipstick when screwed in)
Post by Desantnik-VDV » Fri Dec 06, 2019 8:51 pm
I didn't check any other years but cross-referenced my 2007 to 2008. Other years may be affected as well. I don't want it to puke on a new wheel :D I will let out a little and level it with the top mark of the dipstick.
I had to flush all oils on this new to me NOS 07 Gear Up, with 32 kilometers which sat in the storage for 12 long years. The worst was the gear oil. It was black and very thic. I had to flush it a few times. I may drive some 50-100 miles and then change all oils/filter again.
2007 GearUp NOS
2014 Ural M70
Post by Lokiboy » Fri Dec 06, 2019 9:10 pm
I’ve always put in 135ml. We’ve got the same FD, I believe without the breather. Press on and enjoy the ride.
Post by Desantnik-VDV » Fri Dec 06, 2019 10:47 pm
It's the old style. There are three holes inside the filler bolt (dipstick top) and it has a plastic cap pictured.
2007 GearUp NOS
2014 Ural M70
hillbillybob
Post by hillbillybob » Sun Dec 08, 2019 10:51 am
There are other threads on this topic, one of which I taught me that running a bit less than stated in the manual, might be a good idea. My one wheel drive, is much happier, and cleaner, with 90 ml in the final drive, rather than the recommended 105 ml.
You can get a plastic syringe in a 100 ml or so size, at many places....TSC, Walmart, etc.
(Bought my 06 new in 2015, 40 kilometers on the odometer.)
2006 Ural Troyka "Boris"
2000 BMW R1200C "Schultz"
1999 BMW R1200C "Dooley"
2011 Chinese 150cc Scooter "Johnny" (16,338 breakdown free miles)
Post by stagewex » Sun Dec 08, 2019 11:48 am
My Owners Manual disintegrated long ago. It also had the dreaded completely wrong torque spec for the head bolts as well so good riddance.
Many an owner and even inexperienced dealers unfortunately found out the hard way.
Before it was completely gone I "P-Touched" all the mundane information onto the inside of the truck lid (also my phone).
Comes in handy when you are working on regular maintenance stuff rather than flipping pages of a book.
Fancy and/or fantastical brands of fluids of course are an owners preference:
Stock carb set-up was a mess until...
2006 Honda "Big Ruckus" PS250
Post by jeffsaline » Sun Dec 08, 2019 10:42 pm
If you look on page 61 of the owners manual it has a list of recommended lubricants and that has the correct 3.5 oz./105ml and 4.5oz./135ml amounts.
I too find a bit less than 135ml works well in my 2010 Gear Up.
Post by Desantnik-VDV » Mon Dec 09, 2019 1:07 am
Finally finished refurbishing this 2007 Gear Up. Cleaned the gas tank (did not paint the tank insides per your recommendation Jeff), new fuel lines, filters, carbs cleaning. Installed new manual petcock, quick disconnect with shut off for tank crossover, installed raceaway heat shields between head and intake manifold compliance fittings, new crankcase to airbox curved hose instead of that old thick piece of straight hose. Installed my trusted new Yuasa 310 cold cranking amp battery YTX20HL-BS (YUAM620BH). Changed engine, gearbox and FD fluids. Napa autoparts 20w50 SAE oil (will flash it at 100 km and put Castrol 4T 20w50) and Castrol 80/90 Gear oil...
Valves clearances were too tight (could not even get 0.002 gauge in... set them at 0.003, checked timing, air/fuel mixture 2 turns out, good running at idle and got revs ok (not lean, not coughing).
2007 NOS Gear Up has now resurrected :clap:
She is a VIRGIN. Old but still virgin :D
"Twinmax'ed" it and did some 6 km up and down my street block. It now shows 38 kilometers on odo :boogie:
It took me 6 days of working and waiting for various parts deliveries. Now waiting for tachometer delivery and installation. Need fine RPM tuning and my first test drive next Saturday or Sunday, after which I will change all fluids again.
Last edited by Desantnik-VDV on Mon Dec 09, 2019 12:00 pm, edited 3 times in total.
2007 GearUp NOS
2014 Ural M70
Post by Desantnik-VDV » Mon Dec 09, 2019 1:19 am
I posted this for visually, for other to be careful.
I am using the PDF version of the manual.
Many years ago up to 2007 when I had Urals I was using kitchen measurement cup and going exactly for the book said 105 ml. After poring all into the FD there was still some 10-15 ml left on the walls of the measurement cup. So, yes about 90-95 ml is good for a single WD FD.
2007 GearUp NOS
2014 Ural M70
Post by tgtrotter » Tue Dec 10, 2019 9:55 pm
I'LL QUESTION. POSTAL SCALE ? :?:
The 3 times I've changed my final drive "lubricant" has been measured in fluid ounces. 3.5 the first and third change. No problem. The one time I put 4.5 ounces in, some blew out the upper fill breather cap.
:cheers:
Post by Desantnik-VDV » Tue Dec 10, 2019 10:41 pm
:cheers:
Is 1 fluid ounce = 1 ounce, volume = weight. Some liquids are more dense and heavy... An inch more, an inch less...what's the difference? :D
1quart is 946 ml, which is about 2 pounds. I am used to metric system like Urals in kilometers. See what you see on odo, then do the math. :lol:
2007 GearUp NOS
2014 Ural M70
:FI:Igor
Post by :FI:Igor » Sun Dec 15, 2019 9:57 am
135 ml gear oil, use marks on dip stick. If too much oil it will 'puke out', not a problem.
2015 Ural Patrol (Светлана)
2006 HD Low Rider (sold)
