Rough ride
Rough ride
Hi: I have had my 2013 Patrol for a few months. This is my first sidecar so have nothing else to compare to.
I am used to my R1200GS and find that the Ural is really jarring when riding on rough roads. Solid like an old hardtail.
The shocks are set at the 2nd notch. Do I need to change that??
Would the shocks need to be serviced?
The bike has 34,000km.
John...
2013 Ural Patrol, black
Re: Rough ride
that's...kinda how they roll. but to be certain you might want to compare yours to someone else's.
and if you weigh 140 lbs with full riding gear your opinion of "really jarring" will be different from someone that is 6'5" 240lbs. i guess there's that too...
put your location in your signature. maybe someone on here will want to explore these "rough roads" you speak of.
Scott
2004 Ural Patrol
2004 Ural Patrol
- Hero of the Soviet Union - 2018
Re: Rough ride
I also have a 12gs with ohlins and a 2013 patrol. I am always amazed at the difference. My commute takes me down a bit of unmaintained dirt road and yes, its a jarring, rough ride on the ural.
If I ride the ural for a week, I don't really notice it. But if I switch up often, the difference is very noticeable.
One vote for normal.
Couple things to consider: preload should not (and doesn't for me) effect the ride quality much at all. Ikon is testing a replacement shock for the ural. Not sure how much of the harsh ride is built into the geometry of the machine and how much is the shock itself but we may soon find out.
viewtopic.php?f=11&t=49257
- Andy
Everyday. No excuses.
2013 Patrol
2013 Patrol
- Lmo
Re: Rough ride
Try it....The shocks are set at the 2nd notch. Do I need to change that??
I do not believe that those shocks are not service-able. I'm not holding my breath on Ikon's becoming available.
Re: Rough ride
I have an '07 so the older Russian shocks. Thy have been at the highest setting since the day I picked it up, 4 notches. It's doesn't handle suspension-wise like any other bike I own older or newer.
You have more modern shocks on your 2013 but it is set-up light years behind a BMW GS and it's suspension. No comparison.
You don't have your location listed in your signature line. Perhaps someone who lives by you can check it out or you can try theirs to make sure your rigs "normal" really is normal.
2007 Ural Patrol, 2006 Yamaha TW200, 1995 BMW K75, 1991 Honda XR250L, 1969 BMW r60/2 US model
- Mr Wazzock
- Contact:
Re: Rough ride
Mine feel quite hard at notch 1, but it isn't like they're not compressing, cos they are. Only have to prove it by jacking up a wheel. So yeah what you're describing is what I get also. What I hate in particular is rumble strips, we have them on the approach to roundabouts sometimes, they're an audible/vibration warning to slow down and increase in frequency the closer you get to the island, but is like driving on a corrugated iron sheet.
- hillbillybob
- Party Member
Re: Rough ride
I'm going to go with "they all do that". My 06 has only 9,500 km on it.....rides like a buck board. It has since day one, don't believe it will improve as "kilometerage" increases.
- LRP
Re: Rough ride
Up until 08, Ural made their own shocks and the springs were considerably softer. The suspension travel is only 3 or 4 inches, unlike
your GS which has at least 3 times that amount of travel so it can be a lot softer in the initial travel. Before I had a hip replaced, I installed
a Harley police seat with barrel springs on my 08 Patrol. It helped take away the jarring when I went on AMA adventure rides.
LRP
Dick
LRP
Dick
Army Bird Dog Pilot, Nam.
2018 CT
Traded '08 Patrol
1983 Honda Passport
19 previous motos
2018 CT
Traded '08 Patrol
1983 Honda Passport
19 previous motos
- Snakeoil
Re: Rough ride
My communications with Roger indicates that he is 100% committed to bringing an IKON product to market for the Ural. As you have seen with reports so far, finding a one size fits all Urals has been a bit of a challenge. BillyG just completed his testing. And Roger learned a bit more from his testing and fit-up efforts.
I've run into other Ural riders at events who have said they truly want better shocks for their rigs. The market may not be huge, but it's there so I am confident that a product will emerge with the IKON logo.
You have to keep in mind that Roger IS IKON USA. That means he is busier than a one-legged man in an arse-kicking contest. Fulfilling orders, marketing existing products, and just taking care of business probably occupies 25 hours of every day, 8 days a week. The good news is this is not a new product development, but rather a variation on a theme in that he's making a new product line from an existing product with some modifications.
Patience, Grasshopper, patience.
Re: Rough ride
Rough is a nice way to describe how mine rides compared to my other bikes. Its all part of their charm.
2015 Ural Gear Up
2012 Yamaha Super Tenere
2008 Honda XR650L
2003 Yamaha FZ1
2008 Honda XR650L
2003 Yamaha FZ1
- Buckhorn
Re: Rough ride
I always set the spring pre-load to a setting as light as possible to keep from bottoming out all the time. Once in a while is OK. This seems to give the best ride on any vehicle with adjustable pre-load.
Don't expect to get a very smooth ride with a Ural.
2013 Ural Gear Up Gobi camo
Dimple drain plugs
Shorty left side directionals
2010 Harley Fat Boy
Dimple drain plugs
2010 Harley Fat Boy
- tgtrotter
Re: Rough ride
You may assume a rough ride but honestly my '07 rides surprisingly smoothe to me. My monkey swears it's better than our FLH on RRXs, dips, bumps and washboard. Never hear her swear.
For me potholes bring that "hard tail feel" and a cuss word. But having ridden a few and once owned a hardtail, the Ural is not. On washboard road my '07 definitely does not act like any hard tail Ive ridden. Bouncing and bucking forward, jumping sideways demanding throttle, brake/combo or prepared weight shifts.. Not that the Ural doesnt want to do it but there is noticeable absorption to me. My stock stepped bench seat surely doesn't help much in subduing the ride either.
LMO convinced me to setup my shocks at max cause of my weight. It was all around too stiff for me and my street riding so I turned them back to number 2. I perfer that softer ride. Have yet to bottom out, but I'm not jumping the sucker.
You think some of it may be psyche. You buy a $20k bike, it better ride nice. Now Urals getting up there ?
Im pretty sure most of us want to improve or trick our ride. Myself I would entertain a Koni shock just from experience. Others have their brand preference and some happy with the way a Ural naturally feels. My first upgrade will be a much better seat.
Are you comparing apples and oranges. BMW/Ural. 2 wheeler to 3 wheeled hack ?
My gut feeling is I think your ride is fine. Only because you mention that hard tail feeling and shocks do much more than compensate just for that.
2007 Woodland Green Patrol
2004 FLTRI
1992 Trek 830
2004 FLTRI
1992 Trek 830
