PowerArc-ing Plug wire idea
Re: PowerArc-ing Plug wire idea
Post by GHGoodwin » Sun Aug 26, 2018 5:14 pm
LMO's photos show the left plug wire routed under the alternator housing. I decided to follow his lead but was concerned with the wire rubbing around. Here's how I solved it. I WILL NOT - repeat - WILL NOT ever attempt this again without removing the alternator.
A couple of cable holders.
Mounted on alternator.
Coil side.
Clears everything underneath.
The plug wires, without the boots, fit through. I'll shorten the plug wires tomorrow and button everything up.
Post by Lmo » Tue Aug 28, 2018 11:21 am
You back on line yet?
Post by GHGoodwin » Tue Aug 28, 2018 2:27 pm
Just got her started about ten mins ago. She seems fine. Getting ready for a test ride to gas her up and pick up some sweet corn for dinner.
I've been riding my '14 while this project was unfolding. I knew thaer was a reason I wound up with two. :roll:
Post by Lmo » Thu Aug 30, 2018 11:53 am
Reminds me of old Jaguar joke; you need two, one to drive, while the other one is in the shop.
Post by Lmo » Wed Sep 05, 2018 2:14 pm
Hal !? What's the verdict? Worth the effort?
Post by GHGoodwin » Thu Sep 06, 2018 7:35 am
Not sure yet. I had a couple of minor problems on the test ride similar to the first failure - intermittent "running out of gas" sputter at high speed/load with idle and low speed OK. A big improvement from the first episode so I'm on the right track. Rerouted some wiring, recleaned and re-floated the carbs. New plugs. Cleaned K&N. Oiled cables. Pulled the tank and will clean today. New fuel lines/filters. I'll do a vacuum balance adjust after she's back together.
Anything else anyone can think of?
Post by Lmo » Thu Sep 06, 2018 1:25 pm
Sacrificial offerings?? :wink:
Post by GHGoodwin » Fri Sep 07, 2018 12:11 pm
Also rechecking valves and will run diagnostic on alternator output when carbs are balanced.
n3303j
Post by n3303j » Tue Sep 18, 2018 10:11 am
I have the latest iteration of the P/A ignition sitting in a box because I just couldn't figure out what to do with that oddball coil configuration.
Thank You All for such elegant solutions to this problem!
:cheers:
