2009 GEAR UP Battery swapped out
reimerdavid
Post by reimerdavid » Thu Aug 18, 2016 7:22 pm
Installed new battery in the 2009 Gear up and now the back left turn signal doesn't work. Bulb is good. The front left side flashes very fast. Any ideas
Re: 2009 GEAR UP Battery swapped out
Post by Snakeoil » Thu Aug 18, 2016 9:43 pm
Bulb is burned out.
Plug got snagged during the battery change and is not making contact.
Worse, wire got snagged and damaged an you have an open circuit.
vetsurginc
Post by vetsurginc » Fri Aug 19, 2016 4:30 pm
You can check with a new bulb, or a multimeter to see if you got juice at the socket. If zero, trace back. Check your grounds and connections at the light as well. I had a light go out when the contact strip (to hit the center contact point) sagged to the point of no good contact. Just rebent the strip and all was well. Look for corrosion as well.
Doug
2011 GearUp Vasily (Васи́лий) Main 125, idle 38, Raceway needles, and stock exhaust, MKIII air filter
2010 R1200RT Gustav
reimerdavid
Post by reimerdavid » Fri Aug 19, 2016 8:56 pm
Thanks for the ideas. I plan to trace the turn signal wire with a Tone Generator to try to find the break.
reimerdavid
JPanyon
Post by JPanyon » Fri Aug 19, 2016 10:43 pm
If your relay(s) are under the seat and anywhere the battery, check the relay(s) for correct insertion into their socket(s) as they could have been jostled while getting the battery out/in. Do make sure that wires heading into the socket base are fully pushed inwards all the way. The spade lugs these wires attach to, can too easily be pulled outwards from their "home" position in the socket base. And then, do try swapping relays and see if the trouble follows the relay, or stays associated with the socket and its circuit path. Good info to know before getting frustrated. You've just pushed one of my hot buttons, regarding Ural quality.
Best Wishes
John Panyon,,,Biking since 1961 on wheels left behind but never forgotten
1948 Indian Chief, 1954 Harley Police Special, 1965 BSA Rocket Lightning, 1972 BMW R75 /5, 1975 Norton Commando, 1977 BMW R100 /7 with "Unobtanium" accessories
2002 Ural BC 1st year 750, my unofficial pickup truck for delivering groceries to the disabled.
My Hack Monkey, (rescued from an Animal Shelter).... https://youtu.be/p7pC38IvvoM
Post by VWK75S » Sat Aug 20, 2016 6:49 am
JPanyon wrote:try swapping relays
Relays have no effect on blinkers in 2009.
:lurker: John
2009 GearUp 150,000kms
Post by Snakeoil » Sat Aug 20, 2016 8:56 am
:lurker: John
Doubt that there is a relay in any model year. I see no purpose for it, other than the flasher which is really not a relay. 2000 model has no relay in the directional circuit.
reimerdavid
Post by reimerdavid » Sat Aug 20, 2016 12:37 pm
Found the problem. Accidentally disconnected an electrical connector under the seat when installing the new battery. No power getting to the back turn signal. I did find 2 relays under the seat.
Thanx
Post by VWK75S » Sun Aug 21, 2016 5:59 am
reimerdavid wrote:I did find 2 relays under the seat.
One is for the starter and the other is to prevent you from engaging the starter once the bike is running.
Post by Snakeoil » Sun Aug 21, 2016 11:03 am
D'oh!
JohnBG
General Secretary
General Secretary
Post by JohnBG » Mon Aug 22, 2016 4:34 pm
On my '06, one relay is for the starter and the other is for the high/low headlight beams.
John Grocke aka "JohnBG"
Site Administrator - sovietsteeds.com
'06 Ural Raven - "Vorona"
'09 Kawasaki KLR650 - "Madea"
History:
'98.5 Ural Tourist - "Valentina" - Gone but not forgotten.
2002 Harley Road King FLHPI
1997 Harley Electra Glide FLHTPI
Honda Nighthawk 650 from the mid-80's
1980 Suzuki RM125T
1970 Honda CL100
Love is the feeling you get when you like something as much as your motorcycle.” ― Hunter S. Thompson
Post by VWK75S » Mon Aug 22, 2016 8:17 pm
JohnBG wrote:On my '06, one relay is for the starter and the other is for the high/low headlight beams.
09 high-low connected to switch no relay.
That's the way it is :?
JPanyon
Post by JPanyon » Mon Aug 22, 2016 9:37 pm
oops, I must've taken too long of a siesta when thinking of those relays. Don't feel bad about that overlooked wire though, good work! I once did the same thing on my older California rig, at the first battery replacement. The overlooked wire connected to a solenoid that helped open an emission control butterfly air valve on the air filter housing. Took a few days to figure out why my top speed dropped to 40 mph. lol (valve has been zip-tied open for 13 years now, problem permanently solved...)
