Sidecar driveshaft loose?
epix
Post by epix » Wed Aug 10, 2016 2:27 pm
Today while pulling in the parking lot at work traveling 10mph or so I could hear my driveshaft axle rattle around a bit on my 2011 Gear-Up.
I was in 1WD (rarely use the 2WD) when I heard the noise.. when I parked I grabbed the axle near the u-joint where it connects at the final drive and it would wiggle an half-inch or so in an up/down motion.. is that normal or should it be tight?
Bike seems to feel fine when cruising on the road, just odd this is the 1st time I've noticed the rattle. When going down the road in 1WD mode the driveshaft axle appears to be rotating in a smooth motion.
2018 Ural Gear Up - Terracotta Metallic - TOTALED
2011 Ural Gear Up Forest
1997 Ural Sportsman 2WD (Type 3 Ignition) - SOLD
2008 Yamaha WR250R (306cc kit)
2018 Honda Grom
1975 Honda CB200
berger
Re: Driveshaft axle loose?
Post by berger » Wed Aug 10, 2016 2:33 pm
Need a little clarity as your axle and drive shaft are two very different things and I am having a hard time picturing what you mean. Your axle, the steel rod that goes through each wheel, should not have any play. The stub axle on the hack wheel may rotate some, but that is an indication of worn splines.
Your drive-shafts may have some play due to the u-joints, but they shouldn't "rattle" either.
Berger
2007 Ural Patrol (1st Owner)
Many, Many Mods.
Post by Msblu79 » Wed Aug 10, 2016 2:45 pm
There shouldn't be any excessive play in the u-joints, driveshafts, etc. Small amounts of play in the donut or spline connections is OK but otherwise everything else should be reasonably tight. U-joints should have very little axial or radial play. The play between the pinion and ring gear should only be a couple of degrees. Nothing in the drivetrain should have a 1/2" of play, something is worn out or broken. :?
2010 Black Patrol 95,000km's
epix
Post by epix » Wed Aug 10, 2016 2:47 pm
Bad wording.. the shaft I'm speaking of is what I call the 2wd drive shaft.. has the accordion boots on each end and connects from the final drive out to the sidecar wheel.
I'll take a short video tonight of the shaft play.
2018 Honda Grom
1975 Honda CB200
silverdog
Post by silverdog » Wed Aug 10, 2016 4:24 pm
The slip yoke on 2wd drive line is pretty sloppy on the ones I have seen.
2012 gobi
epix
Post by epix » Wed Aug 10, 2016 7:48 pm
Uploaded the video. Shook the driveshaft at a few diffent places.. seems pretty secure at the u-joint itself. Moves a little bit right at the final drive just forward and back (seems normal), and the shaft itself is does move around a bit but it does make a bit of sense as it would need to do so when riding in rough terrain.
2018 Honda Grom
1975 Honda CB200
cateyetech
Post by cateyetech » Wed Aug 10, 2016 8:08 pm
Looks like the u joint on the side car wheel end is bad.
Post by Albuquralque » Wed Aug 10, 2016 8:29 pm
Too much play IMHO
Buckhorn
Post by Buckhorn » Wed Aug 10, 2016 8:49 pm
Albuquralque wrote:Too much play IMHO
+1
2013 Ural Gear Up Gobi camo
Dimple drain plugs
Shorty left side directionals
2010 Harley Fat Boy
epix
Post by epix » Wed Aug 10, 2016 10:06 pm
Just checked the U-Joint on the sidecar tire side.. it's quite solid. The pusher side does have a bit of play to it.
I removed the rubber accordion boot and scraped away at the grease which was pretty dry (almost mud like) The splines on the "male" portion seem all intact, but "female" portion feels a bit loose (similar to an ex-gf :lol: ) Anyways, how tight should the spline junction be?
Uploaded video below
2018 Honda Grom
1975 Honda CB200
Re: Sidecar driveshaft loose?
Post by Albuquralque » Thu Aug 11, 2016 12:05 am
Way too much play on the splines.
Sidecar driveshaft isn't cheap.....:lurker:
Post by Albuquralque » Thu Aug 11, 2016 12:06 am
If your not going to run in 2wd, you can remove the driveshaft at each u-joint and run with out it until you get a replacement.
n3303j
Post by n3303j » Thu Aug 11, 2016 12:39 am
Your video led to this one (and several with babes in bikinis). This looks like an exposed view of your problem. But your video looked like there was some play in the drive side universal also. The universal should be free of visible play.
Post by VWK75S » Thu Aug 11, 2016 5:10 am
Looks too short.
2009 GearUp 155,000kms
Post by Msblu79 » Thu Aug 11, 2016 8:25 am
I am no expert in this all but to me it seems that the sidecar frame is setup to far away from the FD allowing the shaft to be over extended. There should only be about 2" of splines exposed under the boot. :?
