Removing Sidecar
Re: Removing Sidecar
Post by gobium » Tue Aug 09, 2016 9:27 pm
750 jugs are bigger.
Quicker to cut and re weld very easy job.
You needed as least 1/4 to 3/8" clearance for jug fins to dog leg after alignment. You might get lucky but 9 out of 10 you need to modify.
That is how all new side frame are made.
kennymeyer
Post by kennymeyer » Tue Aug 09, 2016 9:47 pm
Thanks Van, let you know Friday how it turns out!
2013 Ural Tourist (1996 Tub)
2012 BMW R1200RT
Carrollton, TX
Post by Lmo » Tue Aug 09, 2016 10:47 pm
:lurker:
Ural 750 (in my Dnepr) is wider than the original Dnepr 650 too... cut, cut, burn, burn.
tx2sturgis
Post by tx2sturgis » Thu Aug 11, 2016 1:48 pm
Please take pics!
Some of us will probably never do this....but...you never know!
Current Ural: 2013 Ural Solo sT
Previous Ural: 2013 Ural Patrol
kennymeyer
Post by kennymeyer » Thu Aug 11, 2016 6:38 pm
I've been documenting the process... Will share when finished
2012 BMW R1200RT
Carrollton, TX
kennymeyer
Post by kennymeyer » Fri Aug 12, 2016 6:58 pm
IT FITS!!! :boogie: As you can see in the photos there's plenty of clearance. The only issue I have is the rear strut. On the '13 the mounting point on the bike is about 3 inches "behind" where the mounting point on the bike is on the '96. There's not enough adjustment on the rear strut to make the connection, so a new strut is in order. I can deal with that, and since the new struts have both top and bottom adjustments it shouldn't be a big deal. Besides, it's a whole hell of a lot easier than having to modify the sidecar frame :D So at least in my case (YEMV) mounting a '96 Tourist sidecar to a '13 Tourist "solo" works just fine. Next step, matching up the wiring...
2012 BMW R1200RT
Carrollton, TX
mhcallies
Post by mhcallies » Tue Aug 16, 2016 1:49 pm
Very cool!
2015 Gear Up
Post by Snakeoil » Tue Aug 16, 2016 7:25 pm
Good for you.
Nice when things turn out well... Uncommon, too. :wink:
kennymeyer
Post by kennymeyer » Tue Aug 16, 2016 11:30 pm
Snakeoil wrote:Good for you.
Agreed! Too many sleepless nights worrying about this conversation. I'm used to things going the other way :D
2012 BMW R1200RT
Carrollton, TX
JPanyon
Post by JPanyon » Thu Aug 18, 2016 1:59 am
Another item...somewhere around 2005 Ural went to 19 inch wheels. Prior to this they used 18 inch wheels. I'm thinking you'll need a new wheel for your older hack (plus a new spare) to match up with the larger wheels on your new ride. Oh well, life is what it is and not always what we want.
John Panyon,,,Biking since 1961 on wheels left behind but never forgotten
1948 Indian Chief, 1954 Harley Police Special, 1965 BSA Rocket Lightning, 1972 BMW R75 /5, 1975 Norton Commando, 1977 BMW R100 /7 with "Unobtanium" accessories
2002 Ural BC 1st year 750, my unofficial pickup truck for delivering groceries to the disabled.
My Hack Monkey, (rescued from an Animal Shelter).... https://youtu.be/p7pC38IvvoM
kennymeyer
Post by kennymeyer » Thu Aug 18, 2016 6:19 am
My '96 has 19" all the way around, so no worries there. Not sure about the 18" models, but I do know that 96, 97 & 98 Tourists all had 19's.
2012 BMW R1200RT
Carrollton, TX
kennymeyer
Post by kennymeyer » Thu Aug 18, 2016 7:42 am
Found a local welder to modify the rear strut from the '96. Cut 2" from the tube, added an insert to ensure there wasn't any loss in strength and welding it up. Fits like a charm! Attached one of Sean's steering dampeners (thanks Sean) and took her out for a spin around the neighborhood. Have to say the 750 pulls quite a bit stronger than the old 650! Got back in the garage and replaced the original snowmen with a new set. Also added a set of Van's snowman helper springs. Popped the tub back on, affixed two "safety" cables (figured while I had it apart that mod couldn't hurt) and buttoned it all up. Now to see if I can get a 2013 sidecar wiring harness so I don't have to cut off the stock connector... Next step is to get the rig down to Storm's and have Doug check the alignment. After that I should be good to go.
2012 BMW R1200RT
Carrollton, TX
Post by Lmo » Thu Aug 18, 2016 1:50 pm
That'll be me next week. Having to drop the nose of the chair just to get my right valve cover off isn't anything I want to have to do again, especially if I'm "on the road". Not a big deal, just a royal PITA. Since I'll be whacking the front frame tube mount loose I thought I'd move the chair over 3/4" while I was at it.
