Popping Carburetor
roger99a
Popping Carburetor
Post by roger99a » Thu Jan 07, 2016 1:31 am
What are the possible causes for popping backfiring through the carburetor at low to mid range RPMs? Symptoms abate as the engine warms but never completely stop.
Roger
2007 Patrol, the 'trol
Central California
dneprlover
Re: Popping Carburetor
Post by dneprlover » Thu Jan 07, 2016 5:20 am
From those symptoms, I would suggest lean mixture
Neval BMW/MT11 800cc hybrid, Neval 2wd MT10-36, Neval standard MT10-36, Neval MT16, another MT11, BMW/MB650 hybrid , K750m , MB750 and a standard MT10-36 outfit + 2 large sheds full of spares for them.
LRP
Post by LRP » Thu Jan 07, 2016 10:37 am
Check for a broken carburetor slide spring.
Army Bird Dog Pilot, Nam.
2018 CT
Traded '08 Patrol
2008 Royal Enfield cast iron military
1983 Honda Passport
19 previous motos
berger
Post by berger » Thu Jan 07, 2016 11:57 am
roger99a wrote:What are the possible causes for popping backfiring through the carburetor at low to mid range RPMs? Symptoms abate as the engine warms but never completely stop.
Do you know what jets you are running? Bone stock?
Berger
2007 Ural Patrol (1st Owner)
Many, Many Mods.
Post by Msblu79 » Thu Jan 07, 2016 12:57 pm
You are running slightly lean on the low speed circut. Just turn the low speed fuel screw out (CCW) a half or a full turn and see if that takes care of it. Add more until it stops popping.
2010 Black Patrol 95,000km's
scottolds
Post by scottolds » Thu Jan 07, 2016 1:10 pm
Also check your compliance fittings
2009 KLR650
1987 Honda VF700C Super Magna
2011 Ural Gear-UP - отвлекающий маневр
1994 Kawasaki Voyager XII
http://www.rokkitrider.com
berger
Post by berger » Thu Jan 07, 2016 1:16 pm
Msblu79 wrote:You are running slightly lean on the low speed circut. Just turn the low speed fuel screw out (CCW) a half or a full turn and see if that takes care of it. Add more until it stops popping.
Ya, my second thought.... :thumbsup:
Berger
Many, Many Mods.
Post by Wildhorse Cafe » Thu Jan 07, 2016 1:26 pm
Bigger Jets, Bigger Hammer. They all do that.
Post by Lokiboy » Thu Jan 07, 2016 1:35 pm
All the suggestions are valid. My money is on the need to enrich the air/fuel screw by a 1/4 turn or so, and check to make sure you don't have a crack or bad fitting of your compliance fittings attachment to the carbs
Good luck
URAL CT
Post by URAL CT » Thu Jan 07, 2016 3:56 pm
Went through this carb popping exercises not too long ago. I did all the hard stuffs first, like taking carbs apart, cleaning, adjusting the carbs, cleaned the tank & petetcock, etc... nutin' helped. Finally while helping a friend modify his trailer to fit & haul his toys for a trip & during the "I don't need ur help right now". I started doing the easy stuffs inspected the nuts & bolts that involved holding the carbs to the heads, then checked the exhaust & whoa...nut holding the right exhaust pipe to head was loose & one missing causing an air leak. This was causing the popping. Tightened all the fasteners I can get to, just to make sure. Popping stopped & all is well! YMMV...just sayin'
Moral of the story...check the easy ones first. :mrgreen:
CT
2007 Patrol
Plano, TX
Post by rivers » Thu Jan 07, 2016 4:43 pm
URAL CT wrote: Moral of the story...check the easy ones first. :mrgreen:
Amen on the easy/cheap stuff first. Sounds like a lean issue from poor tune/set up or air leak. Bad compliance fitting(s) on an 07 would not surprise me at all. Easy enough to check with some spray carb cleaner, starter fluid etc. Keep in mind you want to tune/adj the carbs on a hot up to running temp motor.
roger99a
Post by roger99a » Fri Jan 08, 2016 11:53 pm
Thanks guys!
Roger
Central California
roger99a
Post by roger99a » Mon Feb 08, 2016 12:10 am
Just an update, the idle jets were dirty and one of the carb flanges was so bad it fell apart.
Roger
Central California
Post by S 854 » Mon Feb 08, 2016 11:28 am
roger99a wrote:Just an update, the idle jets were dirty and one of the carb flanges was so bad it fell apart.
That'll do it... :wink:
Post by eastbloc » Mon Feb 08, 2016 11:37 am
Bad compliance fittings will do it to you every time. It might be environmental, but I always found they had to be replaced once a year on average.
'02 Patrol
'09 BMW F800GS
