Source for the little plug
jgia
Post by jgia » Thu Oct 15, 2015 9:06 pm
That covers the hole you use to find TDC? While prepping for a trip tonight I found it was missing.
Stole the plug from the side of the tub that closes the hole for the sidecar fuse box. I have a cT so there was a plug there instead of wires.
Now I'm short the little plug. For now I may just apply duct tape inside the tub until another plug is sourced.
So anyone know where I can get another plug or a close facsimile there of?
'09 DL650, '02 VFR800 and '15 Ural cT
Who's Ur Grandaddy ?
Re: Source for the little plug
Post by Who's Ur Grandaddy ? » Fri Oct 16, 2015 12:03 am
Any Ural dealer should have some . Also , I'm not certain , but a BMW airhead plug may be the same size .
john
2013 FF gear-up
Mr Cob bulletproof skid plate
Powerarc ignition
Raceway titanium carb needles 4th notch from top
132 1/2 main ... 42 pilot ... air/fuel 1 1/2 turns out
7/64 drilled slides
Leftka III type airbox
Modtop mufflers
n3303j
Post by n3303j » Fri Oct 16, 2015 1:03 am
Who's Ur Grandaddy ? wrote:Any Ural dealer should have some . Also , I'm not certain , but a BMW airhead plug may be the same size .
+1 on the Ural dealer.
My BMW plugs are smaller and just fall out.
Brian Crean
Post by Brian Crean » Fri Oct 16, 2015 7:02 am
A boat drain plug works just fine. I used a quarter in comparison to guesstimate the size, and went to the local ACE hardware store, and hit the marine aisle, Just watch the depth so you clear the flywheel.Insert, flip down the little dogleg lever, and you're good to go.
Mothra35
Post by Mothra35 » Fri Oct 16, 2015 8:48 am
The little plug like the ones in the 12v outlet in your car truck etc works any auto parts store will have one
--2005 Ural Tourist--"Маня"
My U-Tube
---Oliver---Оливер--- :headbang:
Post by stagewex » Fri Oct 16, 2015 10:37 am
They are just a couple bucks from any dealer. And if you buy/order one (or two) chances are you will somehow find the one your are missing the day the new ones come in the mail. Ural Karma.
jgia
Post by jgia » Fri Oct 16, 2015 11:06 am
I measured the hole on the sidecar at 18mm. Then ordered a pack of 10 off amazon. Of course they appear to be coming from China as the expected delivery date is October 30th. Like I stated in the first post, the plug for the hole that would be for the sidecar fuse box wiring is the same size. I borrowed it for the time being and put it in the engine. I put some duct tape over the hole inside the car for the time being.
BTW thanks to one of Gobium's videos for pointing out those were the same plug used in both locations.
Brian Crean
Post by Brian Crean » Fri Oct 16, 2015 12:41 pm
It's amazing how much noise comes out of that itty-bitty hole when the plug falls out.
Red Dwarf
Post by Red Dwarf » Fri Oct 16, 2015 4:52 pm
I suspect that a cover intended for the small holes in an electrical junction box will fit.
Can't find one to check for sure--typical--but they're available cheap at your local hardware store.
2012 Retro
Post by GHGoodwin » Fri Oct 16, 2015 9:55 pm
Clean around the hole and use some non-hardening gasket sealer when you put he new one in.
LaCabra3
Post by LaCabra3 » Mon Oct 26, 2015 12:10 am
I've used a wine cork till mine came from Skis.
LaCabra3
2010 Patrol
R100/7 BMW
Better to have it and not need it than need it and not have it.
dneprlover
Post by dneprlover » Mon Oct 26, 2015 9:49 am
Red Dwarf wrote:I suspect that a cover intended for the small holes in an electrical junction box will fit.
They fit but usually fall out very quickly
Neval BMW/MT11 800cc hybrid, Neval 2wd MT10-36, Neval standard MT10-36, Neval MT16, another MT11, BMW/MB650 hybrid , K750m , MB750 and a standard MT10-36 outfit + 2 large sheds full of spares for them.
GillaFunk
Post by GillaFunk » Mon Oct 26, 2015 12:10 pm
Local hardware store. Rubber plug. Cut to fit.
Use a zip tie through it to make removal easier.
Sgt. USMC 0311, 8156
2011 Gear-Up "سميرة" (Samira). Gone, it not forgotten
JPanyon
Post by JPanyon » Mon Oct 26, 2015 12:25 pm
A Ural that doesn't smoke? Hilarious...
John Panyon,,,Biking since 1961 on wheels left behind but never forgotten
1948 Indian Chief, 1954 Harley Police Special, 1965 BSA Rocket Lightning, 1972 BMW R75 /5, 1975 Norton Commando, 1977 BMW R100 /7 with "Unobtanium" accessories
2002 Ural BC 1st year 750, my unofficial pickup truck for delivering groceries to the disabled.
My Hack Monkey, (rescued from an Animal Shelter).... https://youtu.be/p7pC38IvvoM
GillaFunk
Post by GillaFunk » Mon Oct 26, 2015 1:15 pm
Mine doesnt smoke.
