Help me repair the clutch on my 2005 Patrol
Re: Help me repair the clutch on my 2005 Patrol
Post by BinDerSmokDat » Tue Sep 14, 2021 9:01 am
I've always had to pull the motor, not enough room in there to work for me.
The slotted screws always give me a headache, even with an impact driver, Dremel a bigger slot, etc.
Now what I do is put a dab of weld on the center of the screw, drop a 3/4" nut on, weld the nut to screw.
The heat breaks it loose, the nut makes it easy-peasy to turn.
I can get all the screws out quicker this way than with any other method.
Also, when removing the screws, just get them all to break loose but leave them in.
Then back them all out a little at a time.
If you remove them all without breaking them loose, all the spring pressure is on the last few and they are much harder to pull.
When replacing the clutch, use the new Allen head screws, so next time just heating them will break them free.
nalambright
Post by nalambright » Tue Sep 14, 2021 12:44 pm
So I learned alot on this journey, and you reminded me of one of the things I learned. Early clutch screws, like on my '05, use the slotted head and M8x1 thread. Socket head screws for these dont exist. Ural changed the thread to M8×1.5 and kept the slotted head, these you can easily upgrade to the later socket head screws.
Nate
Current bike:
2017 Ural Gear Up
2005 Ural Patrol project bike
Past bikes:
2007 Ural Patrol
2002 Bavarian Classic solo
nalambright
Post by nalambright » Tue Sep 14, 2021 8:59 pm
Well I got the valves done, one intake and one exhaust had no clearance. I set them all to .004 inch. Next I reset the timing on the type V, that was straightforward. I noticed yesterday I had trouble getting an idle without the enrichners out, today after the lashing I realized it was only the inboard carb. I pulled it down and cleaned it quick once, no luck, so did it again in the ultrasonic. It wasn't until I was blowing things out at the end with the compressor that I found the problem, a load of $#!+ in the main emulsion tube. When I rebuilt them last month, I didnt separate the main jet from the tube. That's what happens when you watch a Harley guy do a CVK32 on Youtube I guess. She's dialed in perfect now, nice smooth idle and starts on the first kick when hot. Now I just gotta mount the license plate.
Nate
Current bike:
2017 Ural Gear Up
Past bikes:
2007 Ural Patrol
Mystery Jig
Post by Mystery Jig » Fri Sep 17, 2021 8:22 pm
Lokiboy wrote:
Wed Aug 18, 2021 3:36 pm
If you strip a screw(s) don’t worry too much about it. Simply use a Dremel and cut the thrust plate #4 around the screw (new costs approx $30 - $40). Saves a lot of time and effort.
use vice grips to remove the screw(s).
Contact Gene at Holopaw for replacement hex screws
was an active member with a wealth of knowledge and has posted dozens of extremely informative videos on both an ‘07 and a 2014 models.
He no longer has the 1.00 pitch older size. I called him this week. Only the slotted version.
2010 Patrol T
2007 KLR650
www.mysteryjig.com
Post by VWK75S » Sat Sep 18, 2021 6:51 am
I know this guy that modified mine :roll:
2010 ST 8000kms
2009 GearUp 160,000kms
