20 MINUTES ON THE HIGHWAY AND IT STOPS (Moved)
- Mr Wazzock
- Contact:
Re: 20 MINUTES ON THE HIGHWAY AND IT STOPS (Moved)
Er, always cycle the engine through one revolution using the kickstart, prior to ....
- aduthie
- Contact:
That's what you hope for, but sometimes, overnight or even days later, the float needle stops sealing and the gas starts flowing. So turning off the petcock (if it's no longer the automatic type) is a sort of "belt and suspenders" method of making sure gas doesn't flow while your back is turned.
Glad you're up and running again!
Andrew Duthie / Nashville Motorcycle Repair / Nashville, TN
- Mr Wazzock
- Contact:
I always turned off my petcocks, still will do for the Bantam (when it's finished). Hose joints can spring a leak too. Guess how I know ...
