Air/ oil separator
Re: Air/ oil separator
Post by windmill » Mon Feb 11, 2019 11:55 am
jaybird wrote:
Mon Feb 11, 2019 11:36 am
At this point, I'm running draft tubes on my rigs and I'm perfectly happy with that arrangement,
It's probably painfully obvious, but what do you mean by "draft tubes"?
I'm picturing a simple tube pointing down like on a diesel engine in a older truck such as my Freightliner had?
Post by jaybird » Mon Feb 11, 2019 12:15 pm
Yes, it terminates under the motorcycle, in the area of the center stand. It's a single tube, I used the plural "tubes" because I have one on my Gear Up and My Retro.
Some people don't like them because they can be a bit "messy", but I'm not a shiner so that's not as important to me.
Post by hotflash44 » Mon Feb 11, 2019 1:23 pm
do you remember the draft tubes were always cut at a 45deg angle on the bottom? guess it provider suction as the air passed by. in the old days my dad would always look under a used car to see if any smoke was coming out,if so he considered the engine warn out. Ah, the good old days :wink:
BlueRockCrawler
Post by BlueRockCrawler » Mon Feb 11, 2019 2:16 pm
Jay, from the video
Van "Sergey can you use this on this?" points at new breather and old engine case
Sergey "Yes but you need shaft shorter"
Here, listen very carefully through both those genius' thick accents
https://youtu.be/wk4Zm-brAhE?t=37
2015 Ural Patrol
1996 Magna Deluxe
previous Honda's were
2002 750 shadow A.C.E.
2004 919
1985 500 Magna
ReCycled
Post by ReCycled » Mon Feb 11, 2019 3:57 pm
On the flat head IMZ/KMZ motors, it is just a rigid tube pointed straight down from the front cover.
David B.
'07 Ural Twourist
Post by jaybird » Mon Feb 11, 2019 4:08 pm
Jay, from the video
Thanks, I saw that, hence my comment about drilling out the center of the new breather valve to accommodate the earlier cam.
There may be some other reason why that won't work, but without having one in front of you to compare it's all just speculative.
The gain may not be worth the effort and expense, I certainly wouldn't pull apart a running engine just to install this new and improved breather.
Post by jaybird » Mon Feb 11, 2019 4:09 pm
Yes, a draft tube.
Post by windmill » Mon Feb 11, 2019 4:11 pm
As a daily rider in the Northwest I'm not a shiner either, but I did find it too messy, even when spraying it with WD-40 in the winter . Perhaps its the difference in climate, but it made a real mess of my back wheel.
BlueRockCrawler
Post by BlueRockCrawler » Mon Feb 11, 2019 7:48 pm
Ah, I see.
2015 Ural Patrol
1996 Magna Deluxe
2004 919
1985 500 Magna
Post by jaybird » Mon Feb 11, 2019 9:16 pm
I went out and looked, my draft tube drops down on the front side of the shifter shaft, between the transmission case and the shifter, it hangs about 3" below the frame, it's not making much of a mess there, and I've never had trouble with it fouling the wheel. My engine is burning a lot of oil at this point, to the tune of a quart to a tank, so if it were going to make a mess it would have by now, perhaps you needed to hang the end of your draft tube a bit more forward and a little lower.
You may not be a shiner, but I've seen photos of you rig, it's a nice rig and definitely a shiner compared to my dirty rust ball :lol:
Post by INSUBORDINATOR » Sun Feb 17, 2019 1:55 pm
I use the POSITIVE crankcase vent system I first learned from my TRIUMPHs & BSAs. It predates DOT requirements, & does a perfect job. It also prolongs Air Filter Life. I turned the elbow on my 02 tourists Crankcase Breather to the UP position, by-passing my air box, & routed a continuous piece of vinyl hose along my frames spine - under the gas tank, & out the rear - ending at my rear fender. I have used this technique on ALL my motorcycles over the past 40 years, with excellent results. I have not observed ANY oil escaping - or visible water vapor. Obviously it works for me.
I do live in a rural area, where no inspection is required. Deliberately.
Post by Tomcatfixer » Sun Feb 17, 2019 2:12 pm
I don't know why you capitalized 'positive', but I like your technique and will implement it onto my rigs. :thumbsup:
Virginia Beach + Gordonsville, Virginia, USA
2015 Ural cT "Mobile Chernobyl", 2001 Ural Patrol "The Patrol", 1999 Ural Tourist "The RPOC", 1994 Honda VFR750F, 1986 Yamaha FZX700S Fazer
Post by jaybird » Sun Feb 17, 2019 2:36 pm
I've seen your system before, very clean install, I've considered using it myself. I'd say the primary reason you're not getting any splooge dripping out the end of that tube is the upward path taken initially and the length of the tube.
The problem I have with that approach is that all that splooge is running back into the crankcase, might not be a problem if you do a lot of extended running, but if you only do short runs it could cause a buildup of condensation in the crankcase.
For me, another issue would be that the tube is running through some valuable and crowded real estate, and might make repairs and maintenance more complicated, but, hey, there are drawbacks to the way I have mine routed too.
tparr
Post by tparr » Sun Feb 17, 2019 2:39 pm
doesn't a pcv valve require a vacuum to open? so if you install a pcv valve and not route it to a vaccuum source its just plugging the breather hole.--- I guess i am having difficulty understanding what "problem" is in need of a fix. my rig is a carbed 2013, so my observations are from this point of view. my vent runs from the crankcase to the airbox. this water vapor and oil mixture is then reintroduced to the cylinders to be consumed. it does not foul up the air filter because the vapors are deposited on the "filtered side" of the intake(they dont pass through the filter). These vapors coming from the case are not harmful to the engine,(every vehicle i drive redirects these gasses back to be burned) why not stick with the stock setup? P.S. im not green, dont care if you dump this directly overboard but seems unnecessary. thats my novice 2 cents worth. happy motoring. Tim
edit
I am wrong about how a pcv valve works. springs hold valve open, vacuum acts to reduce flow. so disregard the first two sentences.
edit 2. i must be bored today since i am sticking my nose in other people business. my apologies
2013 Gear Up, Forrest Fog
new to me in 2018, 14k km
Post by jaybird » Sun Feb 17, 2019 3:28 pm
edit
INSUBORDANATOR Is not really describing his system properly, and I don't believe he has a PCV valve installed. It would be more accurate to say it's a crankcase draft tube, the same as a lot of us use, just routed in a different way.
The mist from the crankcase vent certainly will foul the air filter and shorten the service interval. I don't know what airbox your '13 Gear Up has, but some of the earlier airboxes are a bugger to service, plus the extra expense if you're using paper filters, primary reasons people have done this.
