7" Black Stone Guard Headlight Cover
Got some Russian bikes or parts you want to buy or sell? Advertise your wares here. Individuals only - No dealers in this section please.
This section is for individual forum members to buy, sell, or swap bikes, parts or accessories. Once the item has sold, please edit your post and put "SOLD" in the topic subject title. Dealers and other commercial entities need to post in "The Gray Market" section. All listings must be motorcycle related, preferrably for Urals or Dneprs. No guns, real estate, etc. All items must have an asking price or what you are willing to trade for. No auctions or bids here. If you want to auction an item, put it on eBay and post a link to your item's auction on eBay here.
Whitecoyote
Post by Whitecoyote » Sat May 05, 2018 9:57 pm
I bought this off EBay. Paid nearly $25.00.
I can't get it to fit the Ural. Maybe someone can figure a way to use it. The cover is like new, comes with three clips.
$20.00 shipped to the lower 48.
The $20.00 for this item will be donated to Soviet Steeds Board.
I guess the best way to do this would be for the buyer to send a PayPal to Soviet Steeds for $20.00.
Or a check to myself and I'll make the donation. Whatever works best.
ichbinbier
Re: 7" Black Stone Guard Headlight Cover
Post by ichbinbier » Sat May 05, 2018 11:01 pm
Whitecoyote wrote: I can't get it to fit the Ural. Maybe someone can figure a way to use it.
I never used the clips, I just placed it inside the headlight housing.
2018 Husqvarna Vitpilen 401
2016 CCM GP450
2015 Kawasaki Ninja 300
2014 Ural Gear Up
Post by jaybird » Sat May 05, 2018 11:25 pm
I drilled four small holes in the headlight bezel and tied the stone guard on with stainless steel lock wire, nice and tight, mine's been on for ten years and 80k Kilos. I'd like to say I threw the clips in the trash but I'm a bit of a hoarder so I still have them.
Post by Lmo » Sun May 06, 2018 12:39 pm
"sandwiched" between the headlight and the bezel?
Cecilsan
Post by Cecilsan » Fri May 11, 2018 2:15 am
Alternatively, you can do what I did and use safety wire. Inside the headlight housings are 'winged' clips that keep the headlight in place. I wrapped safety wire around the clips inside and ran them out the front between the headlight and housing. Then put the headlight guard in place and wrapped the wire around making sure to pull it taut with pliers on each wind. On the last go around I ran the wire under the previous one and pulled as hard as I could, snipped off the excess and they've stayed put without issue. You can easily undo the wiring if you get too many bugs that you can't clean and safety wire is inexpensive.
roger99a
Post by roger99a » Mon May 14, 2018 8:36 am
Yes, exactly. I have them on my 'trol like that.
Roger
2007 Patrol, the 'trol
Central California
ichbinbier
Post by ichbinbier » Tue May 29, 2018 12:36 am
Yes! Sandwiched!
Not sure if you can see it but on both the main headlight and spotlight I sandwiched the stone guard.
You can see it better on the spotlight.
Only problem is cleaning the headlight. Need a brush with long bristles or a power washer.
2016 CCM GP450
2014 Ural Gear Up
Mikey
Post by Mikey » Wed May 30, 2018 8:09 am
Has these guards ever demonstrated thier protection? Or is all for looks?
2017 Gear-up Forest fog
