Possibly Helpful Stuff
- Comrade General
- Contact:
- BoBDoG2o02
- Comrade Colonel
Re: Possibly Helpful Stuff
You guys are on the right track. The HH are Sintered pads.Coluralado wrote:I know people have used the HH style. I've just always have gone into my local Japanese bike shop and bought the FA244 Organic pads.
The best part of HH pads is that they are almost impervious to brake fade, but... they are REALLY ABRASIVE to your rotors.
You may get double the pad life as was stated above but you will get half the rotor life.
I use HH pads on my ST1100 cus it goes fast and i sport ride it, HARD. But if normal driving is the use stick with the Organics.
Artificial intelligence is no match for natural stupidity.
'09 ER-6N you figure out what i'm doing with this one.....
'99 Honda ST1100
'06 Gear Up - Sold
'79 Yamaha XS650 Special - Cafe` Project - finished and SOLD!!!
'99 Honda ST1100
'06 Gear Up - Sold
- Comrade General
- Contact:
to follow up...the local bmw-ural dealer had the regular ebc pads in stock.
My rotor is fairly worn and it took a bit for the pads to seat but all is well(now).
Thanks again for the help
Josh
'05 Patrol
'05 Patrol
- antisoshal
- Comrade Colonel
Source of any size Jet you might need for CVK 32 carbs: http://www.jetsrus.com/a_jets_by_carbur ... 28-xxx.htm
2011 Patrol painted Red October Red: Custom Harley Rocket Tail exhaust, 20 Watt LED brake lamps, 20 Watt LED driving lights, Re-wired sidecar with 12 Position fuse box, in dash Fusion Audio weather radio/mp3 player w/128gig SSD storage, Sirius radio and occasionally a beautiful wife.
What would Ivan do? Get plastered, fall off the bike and sleep it off in the sidecar.
carb scew removal tip-if you have Mikuni's or Keihin's
they are not phillips screws, they are JIS. They look they same but the JIS grooves are not as deep so a typical phillips bit won't seat and when turned will have a tendency to strip the head. Either use a JIS screwdriver, file a phillips tip off so it's not so pointed, or use a drywall screw bit on the carb screws.
Also, before unscrewing insert the screwdriver into the screw and give it a light tap (gentle not bfh), this helps loosen the screw. It is also a good trick when taking off the master cylinder cover.
keep your word, no excuses
Ural-it's not just another motorcycle!
2011 Ural T, now only a memory
- Party Member
Mack,
Great resource. Thanks. Now I know where I can get parts locally so I don't have to drive 300 or so miles to get parts.
"Growing old is mandatory, growing up, purely optional."
2013 Ural Gear Up, "Natasha"
Thanks for so much information!
I am riding a 2015 Ural Gear-up, winter camo, which is fitting here in Anchorage, AK.
- Comrade
Great info, Thanks
- Comrade
Big overall wow.
Way Out Western NY
2018 Gear Up; The Black Pearl
1977 Yamaha XS650D
2002 Honda Metropolitan II
2012 Genuine Stella 4T
2012 Vespa LX 150
1977 Yamaha XS650D
2012 Vespa LX 150
Hey I’m a newbie
Will this list work for 2018 URAL 750?!?
I’m looking for a battery replacement
Spark plugs and lube for bike!
Thank you
Toepfer
Thank you
Toepfer
- aduthie
- Contact:
There’s a list for 2014-2018 bikes: viewtopic.php?f=23&t=32977
Andrew Duthie / Nashville Motorcycle Repair / Nashville, TN
