drive shaft range of motion?
Post by hotflash44 » Tue Jul 04, 2017 11:00 am
Hi, guys, with all the drive shaft/donut issues lately i was trying to get my brain around the range of motion maximum up and down movement of the Ural drive shaft. Okay a u-joint at the rear fd end of the shaft then up the shaft is the spline and then the donut with the double set of pins/forks. My confusion is at the donut when the fd moves up high as hitting a bump does the donut flex do the pins move up and down with in the donut ? i would like to see a video of the Ural being driven so i could see the up and down movement of the drive shaft. Most shaft driven vehicles have a u-joint at each end that i understand! Guess i want to know how violent the action is at the donut while driving a Ural especially when fast and bumpy.
Re: drive shaft range of motion?
Post by Lokiboy » Tue Jul 04, 2017 11:09 am
And what will you do with said knowledge? :shock: Donut failure is not that common with the odds of shearing teeth in the FD far more likely in rough off-road and/or overloaded riding.
90,000 km and counting
Post by chaos2 » Tue Jul 04, 2017 11:18 am
somebody had a video of the driveshaft, donut and u joint at speed here not too long ago. The dounut acts like a u joint, allowing change in angle, while also absorbing some shock. If your are getting up and down or sideways motion the holes are probably egging out and time to replace it.
Raceway needles
Modtop exhaust
Post by hotflash44 » Tue Jul 04, 2017 11:24 am
chaos2 that's what i thought it acts like a u-joint, just thought seeing the donut in action would be very interesting. That's one tough little piece of rubber!
Post by hotflash44 » Tue Jul 04, 2017 11:29 am
Lokiboy,the said info would be just for reference, really who has ever seen the notorious donut in action, just to see the shaft forks on both the trans and the drive shaft doing their thing, would be interesting. But the simple explanation that chaos2 gave will do for me right now.
Post by gobium » Tue Jul 04, 2017 11:43 am
You are not going to enjoy ural if you worrying about ,
everything , it is not going to leave stranded in driveway
Post by hotflash44 » Tue Jul 04, 2017 12:09 pm
gobium,you know this forum is loaded with worry wort's,( im not one of them), i am more interested in learning about the mysterious Ural. Im still a newbie 2016 GU with 2500k and not one problem yet,( knock on wood)
