Ural 750 RPM Chart - Speed and RPM
Manscout
Post by Manscout » Sat Jul 01, 2017 1:45 pm
You can view the actual spreadsheet here:
https://docs.google.com/spreadsheets/d/ ... sp=sharing
2011 Ural Patrol
Gillette, Wy
Instagram: manscoutwyo
EncoreJoe
Re: Ural 750 RPM Chart - Speed and RPM
Post by EncoreJoe » Wed Oct 18, 2017 2:06 pm
Thanks for the information.
I live mostly in 3rd gear and at 50 mph it feels like it's time to go into 4th.
It looks like 65 should be normal top speed but I usually stay at 60.
Sent from my SAMSUNG-SM-G900A using Tapatalk
2017 Gear Up
I squandered most of my life. Then I began riding motorcycles.
tx2sturgis
Post by tx2sturgis » Wed Oct 18, 2017 2:14 pm
Cool!
Now can you make one for the 3.89 gears and 18 inch wheels?
I can measure total tire diameter or circumference if needed.
---Brian
Republic of Texas
2013 Ural Solo sT
Manscout
Post by Manscout » Wed Oct 18, 2017 3:22 pm
tx2sturgis wrote:Cool!
I am horrible at math. Lol. What I had to do was run all those speeds and remember the RPM. Then stop, and record the RPM. Then move up the range. I checked each one three times.
Sounds like I need to get an M70 to record the 18". :wink:
2011 Ural Patrol
Gillette, Wy
Post by Tomcatfixer » Wed Oct 18, 2017 7:31 pm
I have a cT with a tachometer and the optional 3.89:1 ratio final drive gearing installed, so I guess I could help make such a chart, but in the meantime Tex, you can read through this thread: http://www.sovietsteeds.com/forums/view ... ilit=Drive
EDIT - Corrected autocorrect
Virginia Beach, Virginia, USA
2015 Ural cT "Mobile Chernobyl", 2001 Ural Patrol "The Patrol", 1999 Ural Tourist "The RPOC", 1994 Honda VFR750F, 1986 Yamaha FZX700S Fazer
Post by Speedbump » Wed Oct 18, 2017 8:23 pm
My 2015 Retro with stock (4.62:1) gears and 18 inch wheels turns 4370 RPM at 60 MPH with induction tach. I too will try to do some recording of each gear's range this weekend.
Glen³
1977 GS550
1979 XS750
Post by wooden nickel » Wed Oct 18, 2017 8:43 pm
According to that, you have a rolling circumference of almost exactly 67". A person should be able to populate a chart with that once they know the gear ratios of the tranny and I think the mothership list those.
tx2sturgis
Post by tx2sturgis » Wed Oct 18, 2017 9:39 pm
Manscout wrote: I am horrible at math. Lol. What I had to do was run all those speeds and remember the RPM. Then stop, and record the RPM. Then move up the range. I checked each one three times.
And here I thought that was your google doc and you could just punch in a few numbers....
I think someone did all this 'figgerin' a few years ago, and its probably buried in the archives.
---Brian
Republic of Texas
2013 Ural Solo sT
fallalotesq
Post by fallalotesq » Wed Oct 18, 2017 9:52 pm
Okay, probably a stupid question but how do you determine the gear ratios?
2004 Ural Troyka (Sidecar Sassy)
1992 Honda Nighthawk 750
2002 Honda CR250
Post by wooden nickel » Wed Oct 18, 2017 10:23 pm
If I did the chart numbers right, it looks like 1st 3 : 1, 2nd 1.9 : 1, 3rd 1.3 : 1, assuming 4th is 1 : 1.
tx2sturgis
Post by tx2sturgis » Wed Oct 18, 2017 10:56 pm
I found a listing in the Owners Manual for my Solo, I assume it's the same for the sidecar models.
Of course the final drive ratio is 3.89 on the Solo:
---Brian
Republic of Texas
2013 Ural Solo sT
Post by wooden nickel » Thu Oct 19, 2017 4:59 am
Ah! That's what I get for assuming a 1 to 1 in fourth. I should have known that an offset output gearbox would use an odd number of teeth in fourth.
I knew I had seen the gear ratios in some tech specs. Didn't find them in a cursory scan.
That also means I was off in the tire circumference too. Now it figures to 79.7 inches. That sounds better.
If I had divided by Pi I might have noticed that meant we were running awfully low profile tires. :roll:
At least the short tire evened out the tall gearing and would still have given the right speed in the chart. Garbage in, almost right answer out. Who knew?
Manscout
Post by Manscout » Thu Oct 19, 2017 10:04 am
If someone get me the corresponding info for the other wheel sizes and ratio, I will add it into that document so they are all in one place and then add them here.
2011 Ural Patrol
Gillette, Wy
tx2sturgis
Post by tx2sturgis » Thu Oct 19, 2017 11:06 am
I measured approximately 13.25 inches on my Solo, from center of axle to tread surface.
That should yield 83.21 inches for a circumference if I did that right. (13.25 x2, then x pi, 3.14)
Multiply 5280 feet in a mile by 12 inches, you get 63,360 feet in a mile.
Divide 83.21 into that and you get 761.4 wheel revs per minute at 60 mph.
Multiplying that by the 3.89 FD ratio, I get 2961.8 driveshaft revs per minute at 60 mph.
Then multiply that by 1.19, (4th gear) I get approximately 3524 rpm at 60 mph for my Solo sT.
I bet its pretty close!
My head hurts now.
8)
---Brian
Republic of Texas
2013 Ural Solo sT
Post by Peter Pan » Thu Oct 19, 2017 12:55 pm
First post: Too low green rev range will hurt the engine fast! On STRONG slopes or when you need force indeed stay between 4500 and 5500 revs with a free engine for to get enough oil to the left cylinder too. Obviously with a new engine you need to babysit the engine and obey the bikes speed order.
Sven
Sophie Travelair
Patrol 2013 a Jim Petitti special.(RIP)
8 weeks 12.000km Oregon - Alaska - Oregon, now in CR 41.000km and counting.
With a DIY foam air filter the rig runs well even in tropical rain. The air box looks then like an aquarium. :moto:
Final drives: 1. at 5000km, 2. at 34.000km(+friction plates)
