Timing Marks on 2019 Flywheel
tubarick
Post by tubarick » Tue Jul 07, 2020 2:31 am
I finished my second service on my 2019 cT. Service calls for checking valve clearances. When I pulled the rubber plug and looked for TDC and Firing marks on the flywheel, all I noticed were machined out grooves. I adjusted the valves the old fashioned way.
Are there any marks on the flywheel?
Рик Гаптилл
2019 Ural cT
2003 BMW R1150RT
2003 Ural M81030 650 2WD
treebone
Re: Timing Marks on 2019 Flywheel
Post by treebone » Tue Jul 07, 2020 12:40 pm
Should still be a mark on there. Notice the grooves are the same size, as you rotate the flywheel you will see a couple of wider grooves, meaning the engraved TDC arrow is arriving shortly. I marked the spot with a dab of white paint a few inches before the arrow so I know when it is close. A small flashlight really helps see the arrow, it is easy to miss it without a light for older eyes.
I try to do this when nobody is around as an old guy draped over the seat peering down with a flash light, slowly stroking the kick starter with his knee might be a traumatic sight for youngsters.
Current- -2015 Gearup Sportsman Adventure Camp Wandawega Edition
Gone but not forgotten- -2009 Patrol, Sold at 26000 klicks
Post by Lofty » Tue Jul 07, 2020 1:10 pm
Yes. You've seen them:
treebone provides good advice regarding paint marks and flashlights.
Post by RC20 » Wed Jul 08, 2020 2:39 pm
I got this from Heindl and yes its really hard to see but the alert on the clue did it ( have done this on an R80GS so was not new to it and still could not see it.)
https://www.youtube.com/watch?v=PA1IQes ... mb_rel_end
As you turn the engine over, you see that series of short machined spots, dimples whatever you want to call them.
Eventually you will come to a long cutout. AS I recall about two small cutouts (forget exact) after that is the timing mark, Not bright yellow or red and white ish that into the metal.
Then is a matter of determine which side is TDC via the loose value and clearance on both in and ex loose.
I actually lucked out and came to rest on the outside one which being easier I wanted to tackle first.
tubarick
Post by tubarick » Thu Jul 09, 2020 10:38 am
Hooray. I found the timing mark and put some paint on it. I'm good to go.
Рик Гаптилл
2019 Ural cT
2003 BMW R1150RT
treebone
Post by treebone » Thu Jul 09, 2020 11:17 am
I put a dab of paint on the flywheel a few inches _before_ the timing mark arrow.
Marking the arrow alone might only tell you it just flew by.
I prefer to slow down when I know it is close to appearing in the port, as it is very easy to rotate past the arrow.
This made sense to me after I missed it a few times and my knee was starting to complain.
Post by RC20 » Fri Jul 10, 2020 1:00 pm
Once I saw the large cutout gap Heindlt talks about it was easy to spot. Didn't bother to put more pain on it, it had white, there is random paint dabs elsewhere though.
