one cylinder
idaho270
Re: one cylinder
Post by idaho270 » Thu Jan 09, 2020 6:19 pm
now no start
did vavle checks oil in valve cover looked ok not much in it
go to start no go swapped out battery with one on tc still no start
drain battery back on charger
https://sovietsteeds.com/forums/posting ... b2b11e433a#
idaho270
Re: one cylinder
Post by idaho270 » Fri Jan 10, 2020 3:42 pm
battery on trickle all night
changed out right coil
12vodc at both plugs
no start
pulled off left throttle body and just a little bit of gunk
still no start
idaho270
Re: one cylinder
Post by idaho270 » Fri Jan 10, 2020 8:08 pm
no start
still no start
changed out coils still not able to turn over
ideas
idaho270
Re: one cylinder
Post by idaho270 » Mon Jan 13, 2020 9:53 pm
idaho270
Contact: Contact idaho270
Re: one cylinder
Post by idaho270 » Fri Jan 10, 2020 5:08 pm
no start
still no start
checked for fuel at injector no spray at both but fuel is present at the 90* junction because i leaked gas all over my rags so does that mean fuel pump working??
idaho270
Re: one cylinder
Post by idaho270 » Tue Jan 14, 2020 1:22 am
what are the chances of both injectors going bad??
Re: one cylinder
Post by Mr Wazzock » Tue Jan 14, 2020 8:05 pm
Very slim.
I've think we've run out of ideas hence no replies lately. :(
Trouble is we're trying to diagnose from a distance, can't look at it up close. All we can go by is what you're tellng us.
Personally I think whatever went wrong the first time, is still in there. Maybe it is wetness related. Sometimes it dries enough so everything works. Then it gets wet again and everything stops working. Maybe the wetness damaged an electronic component. I'm just guessing wildly. :(
Silly question time – you do know it will never start if you hold the throttle open?
idaho270
Re: one cylinder
Post by idaho270 » Sat Jan 25, 2020 8:11 pm
changed out coils and plugs
changed out cps sensor
changed out left ecuthrottle
still no spark
Re: one cylinder
Post by Desantnik-VDV » Sun Jan 26, 2020 4:16 pm
No spark at all on one side?
The rest is just a History:
2014 Ural M70
2002 Ural Barberian Classic
2003 Honda Shadow ACE
idaho270
Re: one cylinder
Post by idaho270 » Thu Jan 30, 2020 9:59 pm
both sides
Re: one cylinder
Post by Desantnik-VDV » Fri Jan 31, 2020 1:50 am
If it's not wet anymore...the battery is good, ground is good?
Spark plug wires are within resistance specs?
Are Ignition switch, kill switch good?
Could be CPS sensor, sensor to flywheel gap (0.1 to 0.17mm), engine management throttle bodies...
Engine management diagnostics tool reading?
2014 Ural M70
idaho270
Re: one cylinder
Post by idaho270 » Mon Feb 17, 2020 12:32 pm
I replaced the CPS no joy
replaced right ecu with new one no change
any ideas
Re: one cylinder
Post by Mr Wazzock » Mon Feb 17, 2020 1:45 pm
Read the whole topic again from the beginning. We must be missing something but I don't know what.
while swerving to miss a tree in middle of road
Something happened here that started it all but I don't know what. Apart from an insane amount of water.
Any chance of getting any error codes read from the ECU's?
idaho270
Re: one cylinder
Post by idaho270 » Mon Feb 17, 2020 11:15 pm
i tried codes nothing comes up.
tussocktopper
Re: one cylinder
Post by tussocktopper » Wed Mar 25, 2020 6:09 pm
I have had a vaguely similar problem with a 2014 for the last 3 years. Finally no spark no fuel pump. After trying checking all I could think of using patch leads etc. I gave up and took it to the Australian importer 700kms away. It turned out to be a loose contact on relay1. So try disconnect and clean these connections. Good luck hope this helps.
Re: one cylinder
Post by Mr Wazzock » Thu Mar 26, 2020 11:24 am
That's a good point. All the contacts in my 3 relay sockets were very poor, almost loose. I had a developing starting problem, currently I have relays 1 & 2 removed and bridged direct with wires. Also had to tighten up the socket connectors where those wires plug in. Needs looking at more thoroughly, on the to-do list.
