Oil Pan bolt washers
RAMDrive
Post by RAMDrive » Sun Jul 14, 2019 3:08 pm
Yesterday I replaced the oil pan gasket with the recommended silicon reusable gasket. I did not realize the bolts used crush washers, which I didn't have. I did use standard washers, but that backfired and oil is dripping from one of the bolts close to the shifter. The solution I plan is to drain and clean the oil. Then put some type of RTV in the leaking bolt hole and remount everything. Does someone know where I can order replacement crush washers, and a part number too?
'17 Ural Patrol -- "Oil Slick"
'99 HD Fatboy -- "The 1-Eleven"
Trumpetwasher
Re: Oil Pan bolt washers
Post by Trumpetwasher » Sun Jul 14, 2019 5:07 pm
Once you determine the bolt size, go to an industrial supply and ask for Dowty washers that size.
Black Power Train
3.89 Final Drive
Reverse Hand Shift
Sidecar Power Panel
Handlebar Power Outlet
Deluxe Seating
Sidecar Side Panels
Armrests
Double-Spring Saddle
Santamaria Foot Rest
Custom Nose Art
Dnepr Leg Shields
XMT-MOTO Hand Guards
All LED lights.
Post by windmill » Sun Jul 14, 2019 6:53 pm
They're safer and easier to use than crush washers as they only need to be lightly snug to seal and stay in place. They will also last many years and oil changes.
I've seen them in auto parts stores too.
Spat
Post by Spat » Sun Jul 14, 2019 11:20 pm
10 years ago I replace my drain bolt washers with nylon drainbolt washers from the local Ace hardware, still using those same washers.
Spat
FLHGSSXDR.Patrol
Proud member of the Patrol Patrol
Fall in love with a person who enjoys your madness
Red Green: If life gives you lemons, throw 'em into a quart of vodka.
Red Green: Duct tape or zip tie,,, fixed is fixed
If we don't change direction soon, we'll end up where we're going.
Irwin Corey
Trumpetwasher
Post by Trumpetwasher » Sun Jul 14, 2019 11:39 pm
He's talking about the bolts that hold the pan on.
Black Power Train
3.89 Final Drive
Reverse Hand Shift
Sidecar Power Panel
Deluxe Seating
Sidecar Side Panels
Armrests
Custom Nose Art
Dnepr Leg Shields
All LED lights.
Post by windmill » Mon Jul 15, 2019 12:09 am
Interisting, my 2007 has plain and split washer combination. My 2018 has Dowty washers. Didn't know they used crush washers for a time, kinda threw me.
Here's a source.
https://www.mcmaster.com/93786a125
Post by RC20 » Mon Jul 15, 2019 2:01 pm
Unless the seal did not go around the bolts, any washer should work.
Possible bolts go into the empty space but that unusual.
Granted I am not a Ural specialist by any stretch.
I have replaced a lot of differential covers with silicone seal and no crush washers.
Post by Snakeoil » Wed Jul 17, 2019 9:27 am
If the bolt holes for the pan are thru-drilled so that they are open to the sump, that is what causes oil to seep from the bolts. The gasket is not in play as long as it surrounds the bolt hole in the pan/sump flanges. Easy fix is to you Loctite 567 on the bolts. It is both a sealant and a thread locker. This saves you having to compress the gasket excessively. Just snug them up and they will stay put. And now you can use regular flat washers.
I've been using 567 on screw-in petcocks for years. Triumph used Dowdy washers and they are not 100% foolproof. 567 is. I think you could put a petcock in finger tight and it would never leak nor move.
Post by RC20 » Fri Jul 19, 2019 7:11 pm
Thanks, makes sense and the 567 would be a nice move.
Be sure to get the holes clean of oil, any residue needs to be gone.
One of the modern brake cleaners works fine. FDX cleaner is great stuff if you can find it, non haz and as good as TriClore was.
