Led Headlight
jcbigears
Led Headlight
Post by jcbigears » Sat May 25, 2019 7:59 am
Hi all,
After much consideration and advice from this website, I decided to upgrade my headlight to LED using an all-in-one unit. The one I chose was the Narva 72104 https://www.narva.com.au/products/72104.
Now, this is all "in my opinion" so please feel free to disagree. The reason that swayed me for this was that the standard headlight design, even a high-quality one, relies on a single point of light being reflected and bounced to get a good beam. No matter how good the quality of the lens and the bulb, it's never going to be as good as a purpose-built unit. There will always be glare and stray photons. An all-in-one LED unit can have multiple light sources and also multiple lenses to give the rider the best beam.
I'm pleased to report this was the easiest improvement yet! The screw at the bottom of the light can is removed, and the existing headlight lifted away. There are two bulbs, one of which connects with an H4 connector, and the other "parking" lights with a ground (black) and power (yellow) wire. These are easily removed.
The clips holding the reflector into the ring were exciting to get out. Push down on one side to unhook it from under the curved edge of the ring and watch where it lands when it springs out.
The new unit fits perfectly, and the clips inserted.
The H4 connector clips on without adaptation. The "AMP" connector was then cut off, and the blue and white wires joined together and attached to the yellow wire. The grey wire connects to the ground.
And what do I get? It all works, and works incredibly well. The "position" light is a horizontal bar, but with the engine on the headlight shines a sharp bright beam. The highbeam is perfect. I'm very happy with it.
It then began to rain so I could only take these photos down my driveway tonight. I'll take it to a wall when the weather clears.
I can understand the attractiveness of installing a H4 LED bulb +/- a new reflector for it's simplicity, but this really wasn't hard at all.
What do you all think?
2016 Ranger, left hand sidecar, underside of the equator
atlasheating
Re: Led Headlight
Post by atlasheating » Sat May 25, 2019 8:40 am
I am impressed but: Wow those things cost a pretty penny. 1 little rock could ruin your whole day....
jcbigears
Re: Led Headlight
Post by jcbigears » Sat May 25, 2019 9:48 am
"Virtually unbreakable polycarbonate lens"
Fingers crossed as well
Re: Led Headlight
Post by Lofty » Sat May 25, 2019 1:51 pm
The real test will occur when riding at night, with oncoming traffic.
If any number of drivers flash their high beams at you, you'll want to adjust the aim of your new headlight. If they continue to flash their headlights, and you can't (or don't want to) aim your new LED light any lower, you may have to consider reinstalling the OEM headlight lens.
Re: Led Headlight
Post by Lmo » Sun May 26, 2019 2:51 pm
Leave the headlight nacelle just loose enough that you can deflect if up/down as required; the "aim" will vary with the load you're carrying.
Personally... I'm an H4 fan; I feel the down-road light pattern is superior to LEDs.
Re: Led Headlight
Post by windmill » Sun May 26, 2019 4:07 pm
I see some foreground hot spots that would be of concern to me. They draw ones gaze, causeing ones vision to adjust to them, and diminish the ability to see whats in the dimmer distance. Hard to say as images can be deceptive, but I threw out a headlight that produced similar results.
Not a very good image as the road is wet and crowned, but the H4 + LED I ended up using doesn't have those hot spots, or artifacts (shadows) often encountered.
Low
High
jcbigears
Re: Led Headlight
Post by jcbigears » Sun May 26, 2019 4:15 pm
I’ll post some better photos when I can. It’s pouring with rain down here at the moment and will do all week...
Re: Led Headlight
Post by siberman1 » Mon May 27, 2019 11:39 am
...snip....
I agree with Windmill. I had a LED headlight and it really sucked unless on Hi all the time. It gets pitch black out here in the mountains, zero street lights and so on.
I installed a 5000K 35w Hi/Lo HID in a Hella glass. It works better than H4 IQ, and has zero "hot spots" as Windmill calls them. It is also about $80-$90 total (depending where you get the 2 parts) which less than 25% of the Narva deal. I found the HID to be much better than the LED headlight.
JMO
Mikey
Re: Led Headlight
Post by Mikey » Mon May 27, 2019 12:21 pm
JC, let us know how it works for you. As you said, it's your opinion, I'd love to hear you views.
2017 Gear-up Forest fog
Marine Corps Codu
Re: Led Headlight
Post by Marine Corps Codu » Mon May 27, 2019 12:30 pm
You might consider buying a lens protector from Hemisphere Offroad (www.hemisphereoffroad.com). Excellent products and MUCH cheaper than replacing the light, in my humble opinion.
Keith Birkhofer
Marine By Choice
Former Bikes:
1947 Cushman Motor Scooter
1958 Cushman Motor Scooter
1964 Yamaguchi
1965 Honda 250
1968 KZ100
1960 Honda 55 (2 of them)
2002 Honda Gold Wing
2006 Ural Patrol
2005 BMW GS1200
Re: Led Headlight
Post by windmill » Mon May 27, 2019 1:04 pm
JMO
I looked at HIDs but those few correctly engineered for a H4 seemed excessively complicated with their external ballasts, moving or dual bulbs, lifespan not much better than a Halogen, and expensive.
Some that the cheaper ones technically fit a H4 but totally compromise the beam patterns, and glare horribly without any meaningful difference between high and low beam.
The Phillips design H4 LED bulbs function the same as a halogen bulb in a H4 reflector, and don't compromise either beam pattern.
