New Ural pulls to right
pbrowne
Post by pbrowne » Sun May 19, 2019 7:13 am
I've had my 2018 Ural for 10 days and I'm almost ready to sell it! It pulls heavily to the right. It's dangerous to take my left hand off the handlebar because it immediately darts to the right. Even going in the opposite lane it will climb back over the crown of the road to the right.
I've increased toe-in in several steps, disconnected the sidecar brake,and put maximum pre-load on sidecar shock. I've kept lean-out at 1 1/2 - 2 degrees.
Nothing has made any difference.
The only thing that I have noticed is that the rear wheel points slightly right if I place a straight edge along the front and rear wheels. The front of the rear wheel has about 3/16" space to the straight edge, which is in contact with the rear of the rear wheel and both front and rear of front tire.
Help!!!
Shepherdstown, WV USA
2018 Ural GearUp "Arwen'
Previously owned: Suzuki Burgman 650 with Texas Sidecar, BMW R1200RT, BMW F650GS, BMW K1200LT, Honda Nighthawk 750, Honda Hawk, Honda Pacific Coast
Re: New Ural pulls to right
Post by Albuquralque » Sun May 19, 2019 7:42 am
How close is your dealer? If they are close, I would take it back and have them make it right.
What do you have your toe-in set at now?
Post by harryball » Sun May 19, 2019 8:13 am
+1 on take it to a good dealer. Not a dealer, a GOOD dealer.
Otherwise,
Check wheel true. If a wheel is not true, you will have trouble aligning it yourself.
Set toe-in to 3/8" and leave it.
Use the rear rotor to give it 2 degrees of lean out, be prepared to add a bit more lean.
Ride, add more lean if needed, you should not need to go over 3 degrees.
You mentioned rear wheel not tracking behind front. Check your FD is mounted properly and there is no debris between the FD and swingarm. After that, I'd suspect the swingarm itself.
If none of that turns up a solution, time to get it to a good dealer to go over.
LRP
Post by LRP » Mon May 20, 2019 11:35 am
I had the same trouble with my 2008 Patrol. You should align the sidecar to the rear wheel track to solve it. Disregard the front wheel.
Set toe in at 3/8-1/2" relative to the rear wheel track.
Army Bird Dog Pilot, Nam.
2018 CT
Traded '08 Patrol
2008 Royal Enfield cast iron military
1983 Honda Passport
19 previous motos
Post by rivers » Mon May 20, 2019 1:45 pm
2018? So I'm guessing you bought it new? You're prolly a victim of all too common "improper dealer set-up" from an inexperienced dealer. For the money you got invested take it to a "good" dealership and have it set up right. It's a Ural so any future glitch is a possibility but for the money it should at least handle/run great for a sidecar outfit right off the showroom floor. It's normal for a new sidecar pilot to have to learn how to safely drive an outfit. Tricky enough with a properly set-up rig and takes time but what you're describing is not normal. Yeah sucks to have to bring a brand new Ural back to a dealer. But for the money invested it'd suck a lot more to get frustrated and just not ride it. Your mega buck investment entitles you to at least have right from day one!
For any prospective buyers out there...When buying a "new" Ural, dealer selection is CRITICAL.
Post by Lmo » Mon May 20, 2019 2:01 pm
+1. For now. Definitely a "inexperienced dealer" issue.
You mentioned that you're bumped the alignment. Since you know how this works, I'd suggest bumping in MORE toe-in and test ride it. Keep increasing toe-in until it's ride-able. THEN set up your alignment rig and measure it the set-up. If it turns out to be something ridiculous ( 1" + ) then start investigating.
The "old method" of aligning motorcycle front wheel/rear wheel involved stretching a piece of twine along the sidewall of the tires, taking care to ensure that the twine wasn't climbing over the tread block of one tire, but not the other (which would throw off the measurement).
EDIT
That would certainly induce some "right" steer into the machine; the back of the bike would want to swing to the left (think ladder fire truck with the tiller man in the back).
Post by Lokiboy » Mon May 20, 2019 3:14 pm
Being in WV, you’re just a stones throw from Heindl Engineering who are one of the best Ural dealers in the US. Make an appointment with them and bring your rig to get it set up properly.
90,000 km and counting
Post by Wildhorse Cafe » Mon May 20, 2019 5:38 pm
Maybe to much side car brake drag? Easy to check out.
2011 Patrol Higgs Bison Super Collider formally known as the Orange and Silver Pumpkin Coach
2006 Shinny Black, Tourist, Tatyanna
Post by Wildhorse Cafe » Mon May 20, 2019 5:47 pm
just incase
dcsmitty
Post by dcsmitty » Fri May 24, 2019 3:45 pm
My 2015 cT has always pulled to the right slightly and the rear tire only gives me about 4000 mi so I started re-adjusting. Went to 30mm toe-in (almost 1") and that didn't stop the right pull but it then started weaving back and forth during braking. I too noticed that there is a gap of about 1/8" at the front of the rear wheel with a 8" fluorescent tube laid across the front and rear tires. Reduced toe-in to 10mm but have not tested yet. May try aligning with rear tire only to sidecar. Will have to attach 8" tube to right side of rear tire to do that.
Post by Lokiboy » Fri May 24, 2019 4:07 pm
4000 miles is pretty standard for Duro 308s
dcsmitty
Post by dcsmitty » Fri May 24, 2019 7:40 pm
I had the Heidenau K-28 on there and I thought they were a longer mileage tire? Also just figured out why no contact at front of rear tire. Recently had Heidenau K-28 replaced with Metzler and that tire is 1/4" narrower at sidewall than the Heidenau. Needs a 1/8" spacer on rear tire to keep the straight edge in contact at all 4 points and parallel to the centerline of the bike. I think by aligning without a spacer will cause the front wheel to turn slightly to the left until the straight edge contacts the rear section of the rear tire. This will make the observed toe-in actually less than what is called for.
Location: Heredia, Costa Rica/screwing the heck out of the hack
Post by Peter Pan » Sat May 25, 2019 4:37 pm
Hello Paul, have a look at my answer on the sidecar.com forum.
Welcome in the club. Above video should help a lot.
Sophie Travelair = Patrol 2013 =>43.388km+nacked :shock: :pot:
Engine: 1.43.388km :gahhh: Back home and under construction.
Post by Mr Wazzock » Sat May 25, 2019 4:44 pm
My still original rear Heidenau K28 has now lasted 9,000 miles. Summat not right sure nuff. Does not pull to one side either.
Post by RC20 » Sun May 26, 2019 2:34 pm
I have one of the magnetic degree gauges
It went in the box to take with me as a quick check on setup for the Ural.
1 x CB700 SC (RC20 is the actual in house production Model)
