Starter Question
HassoBoxhead
Re: Starter Question
Post by HassoBoxhead » Tue May 14, 2019 2:43 pm
Thing is, I replaced the battery with a brand new one...same issue with no starter at all (not even a click).
2014 Slate Grey Gear Up
Post by rivers » Tue May 14, 2019 2:54 pm
For me that confirms your issue is in the circuitry between the battery and starter. You next investment should be in a DMM/VOM.
HassoBoxhead
Post by HassoBoxhead » Tue May 14, 2019 7:29 pm
I started with replacing the relay under the seat. Took the old one to an auto parts store, found one like it and installed it at home tonite: starter cranked right up, problem solved! Thanx to all for the advice and the patience!
Post by GHGoodwin » Wed May 15, 2019 7:48 pm
Also check the starter. The solenoid might not be able to throw the gear into the flywheel if the gear shaft is gunked up.
A bit late to the party.
Post by Mr Wazzock » Thu May 16, 2019 1:58 pm
OK then! But do you know which of the 3 relays you replaced?
Notwithstanding this is why it's a good idea to carry a spare
