2019 Rear tire flat....
Re: 2019 Rear tire flat....
Post by windmill » Fri May 10, 2019 9:15 pm
RC20 wrote:
Thu May 09, 2019 7:31 pm
If you were dragging the brake to any degree the smell would be awful.
I disagree. I had a pebble get between the caliper and pad on the front brake of my Patrol that caused it to drag. When I finally noticed it, the disc was red hot, but there was no smoke or smell.
tas7107
Post by tas7107 » Sat May 11, 2019 11:15 am
I will mark the tire and see if it slips. As for the Rear brake. I wear the crown of the blind Dumb a$$. No need to call me your majesty. Dropped rig of at Raceway Ural and while telling Robbie about my break pad woes, He looks at it while still on the trailer and with great restraint doesnt call me a dumb a$$ "One of your brake pads on is on backwards".
Several lessons here.
1) Wear your glasses when changing tire on side of the road. And dont lose patience.
2) Get flashlight out when in dimly lit garage and see #1 before inspecting issue.
3) Just because you have been wrenching on your stuff since you were a little kid dont jump to conclusions
4) Dont be a Dumb a$$ so that you look like an idiot in front Dealer.. LOL
Terry
Tigard, Oregon
2019 GU Slate Grey
2015 CRF1000l Africa Twin
Post by RC20 » Sat May 11, 2019 11:34 am
All good wisdom. One of the issues with Pumps (3 phase/480 volt) is they can run backwards and work. Kind of standard any time a flow issue to check that. Had a off site guy tell us to check one we were pondering and yep, it was running backwards. Talk about embarrassed.
Post by RC20 » Sat May 11, 2019 11:37 am
If you read what I wrote you will note it said "Dragging Brake". A pebble is a different issue. Dragging can be caused by operator or a sticky puck and the entire surface is affected .
Post by Lokiboy » Sat May 11, 2019 11:59 am
tas7107... words to live buy.
90,000 km and counting
Post by Mr Wazzock » Sat May 11, 2019 6:16 pm
Post by Mr Wazzock » Sat May 11, 2019 6:24 pm
I've had a flat both front and back, in each case due to the inner tube chafing on a ridge created by having two rim strips with one overlapping the other. Dealer had some extra wide rim strips so when tubes were repaced we had those out too and replaced with one wide one in each. Both new tubes leak bit. I need to check the pressures at least once a week. The sidecar one practically loses none at all, and that's the last surviving factory fitted one. Go figure.
Brake pedal, yes I ride with the ball of the foot on the footrest to make sure I'm not inadvertently pressing it slightly.
The pusher valve does get banged up if you have a flat there. Mine was too.
tas7107
Post by tas7107 » Sun May 12, 2019 9:01 pm
Mr Wazzock, where did you find a picture of me?? :lol: :lol:
Terry
Tigard, Oregon
2019 GU Slate Grey
Post by Mr Wazzock » Mon May 13, 2019 6:01 pm
8)
Post by windmill » Tue May 14, 2019 9:52 am
The pebble was between the caliper and pad, keeping the pad against the disc just like a dragging brake. The heat eventually caused both pads to drag, and when I stopped it actually locked up until it cooled off. Both pads were glazed on their entire surface.
keetmanaa
Post by keetmanaa » Tue May 14, 2019 10:35 am
Has anyone installed rim locks on the pusher wheel? Common practice on motorcycles that run off road with lowered pressures.
2015 Gear Up
2010 Yamaha WR250R
2004 DL650 V Strom
Post by BigJames » Wed May 15, 2019 12:12 am
ouch... admitting a mistake is almost the same as fixing a problem. I don't use rim locks, but have 18" wheels on, well for now, 2 of my Urals. Rim strip tape stopped my repeated flat tire woes.. In my case it was those pointy nipple heads that kept getting the tube. Been told that probpme is gone on the '19 model. On the 19" wheel on 1 of, well for now, 1 of my Urals, no problem except for forgetting the sidecar wheel is always powered (Sportsman, I know, how could i forget) and ripped valve stem right out if it...
Bullethead
Post by Bullethead » Fri May 17, 2019 6:55 pm
Yup, yup, yup on the pressure check deal.
Way Out Western NY
