New Gear Up - Broken parking brake cable
LVGS
Post by LVGS » Sat May 04, 2019 10:33 pm
During the orientation to my new Gear Up at the dealership last weekend, the parking brake cable broke i.e. at the handlebar end (see pics attached). It appears several members have had the same thing happen to them (viewtopic.php?t=49908) and therefore, I assume mine came the same ‘bad batch’ that plagued others.
The dealer has submitted a warranty claim and anticipates we will receive a replacement cable soon. However, it appears that the broken ‘stop’ was imbedded in some plastic which is still in the lever. Question: is it merely a matter of removing the imbedded stop and plastic, and installing the new cable? Or, should we be ordering a new lever with the cable already attached? If the latter, the wire leading to the dash would also need to be disconnected)
Needless to say, it was very disappointing given we were in the process of taking delivery; it was certainly no fault of the dealer. Any help/thoughts would be very much appreciated.
Thanks.
Nanoose Bay (Vancouver Island), BC CANADA
In the garage:
‘18 Ural Gear Up
‘10 BMW R1200GS
Eric N
Re: New Gear Up - Broken parking brake cable
Post by Eric N » Sat May 04, 2019 11:03 pm
The lever looks fine. The "stop" is wrapped in a plastic bushing. If you look at the underside of your lever and kinda close the parking lever, you'll see a hole in the lever where the stop/ bushing is. Should be able to just push it down through that hole, installing the cable is the reverse, the stop will go up into that hole and then you feed the cable around.
2013 Retro Solo
2001 Patrol - Sold
Post by Pterodactyl » Sat May 04, 2019 11:11 pm
Mine broke in the same location a week after taking delivery from my dealership that is 720 miles away. I emailed him a picture of the broken cable and the VIN on the frame. Had a new cable in about ten days. Took about 30 minutes to install. Take pictures to get the routing correct. Dealership is Raceway in Salem, OR. Very happy with them.
The Outpost, Silver City, Montana
Team Pterodactyl
Post by Pterodactyl » Sat May 04, 2019 11:36 pm
Posted in wrong thread...
Team Pterodactyl
Post by Mr Wazzock » Sun May 05, 2019 9:24 am
Yes take it out, they are supposed to be replaceable. Someone needs to find out why these cables break, implies they're being stressed at that point. The previous version cables didn't break, or as much, AFAIK.
LVGS
Post by LVGS » Sun May 05, 2019 12:47 pm
Thanks Eric, that's exactly what I needed to know. It was painfully obvious once I did as you suggested. Now, just have to wait for the new cable...
In the garage:
‘18 Ural Gear Up
‘10 BMW R1200GS
LVGS
Post by LVGS » Sun May 05, 2019 12:48 pm
I wonder how prevalent the problem is; my dealer indicated that it was the first one he had ever seen.
In the garage:
‘18 Ural Gear Up
‘10 BMW R1200GS
Eric N
Post by Eric N » Sun May 05, 2019 7:39 pm
I've had to replace two rear brake sensors, my speedometer sometimes thinks I'm driving when I sit still, my paint at the gas tank is bubbling, but I'm still on my original parking brake cable.
2013 Retro Solo
2001 Patrol - Sold
Post by windmill » Sun May 05, 2019 8:30 pm
A bunch of cables were made with the barrel assembled backwards. The barrel is a small casting with a funnel shaped hole for the cable, and is soldered to the cable. Someone was assembling them with the large end of the funnels cone facing the cable, instead of away from it. The cone shaped plug of solder will eventually pull out, rather than acting as an anchor like the head of a fastener.
cycleman
Post by cycleman » Thu May 23, 2019 11:52 am
One thing I've found with some BMW clutch cables, the ferrels where not smoothed off to allow the ball end to rotate a bit to releave the stress on the cable. They would break just where the ferrel and the cable joined. The portion that the cable went into was not round, but square. Overtime this would break a perfectly good cable. File the edges off the ferrel so it could rotate, and it caused no further issues. Something to check.
Not quite the same thing, but a cable is a cable.
Post by Lofty » Mon May 27, 2019 8:09 pm
I recently received a new (warranty) replacement fuel tank for my GU, in recognizance of significant paint bubbling and eventual delamination. Depending on the severity of the same on your rig, it might be worth the effort to initiate a conversation with your dealer. Mine was a months-long process, frustrating at times, but I'm glad to have attended to it.
Know that 2018 is a one-year-only design specification for the fuel tanks.
Good luck.
Marine Corps Codu
Post by Marine Corps Codu » Mon May 27, 2019 9:02 pm
I bought my 2006 Patrol from Raceways when Jim owned it. Great service and very knowledgeable. My next trip into Salem I will be sure to stop and meet the new people there.
Keith Birkhofer
Marine By Choice
Former Bikes:
1947 Cushman Motor Scooter
1958 Cushman Motor Scooter
1964 Yamaguchi
1965 Honda 250
1968 KZ100
1960 Honda 55 (2 of them)
2002 Honda Gold Wing
2006 Ural Patrol
2005 BMW GS1200
Post by Pterodactyl » Tue May 28, 2019 12:14 am
I was shopping around for a month for a new Ural. I knew what I wanted but was looking for a decent deal. A buddy from Fairbanks had dealt with Robby on a warranty issue while traveling and a local guy had also dealt with him long distance; both speak very highly of him and his mechanic. I viewed his website and sent him an email at 8 PM on a Sunday. Unexpectedly, he responded a few minutes later. We exchanged several emails that evening and by 11 PM I had sent him a deposit via PayPal. I’ve had the rig two months and my experience with Robby has been great. He responds quickly to emails, has explained things patiently when I have questions, talked me through trouble shooting an issue and, of course, sent me replacement parts under warranty. I could not be happier.
Team Pterodactyl
