Rear brake pedal freeplay
Re: Rear brake pedal freeplay
Post by Mr Wazzock » Mon May 06, 2019 4:57 pm
jcbigears wrote:
Sun May 05, 2019 5:21 pm
On a slightly different matter, the sidecar brake squeals but I’m thinking this is from the very low kms don’t since new.
The stock organic pads can squeak a bit. I'm now using semi-sintered and yet just lately the rear has started doing it again.
:FI:Igor
Post by :FI:Igor » Tue May 07, 2019 9:02 pm
Yeah, what 'Cookiemech' said. I think the reason the bleed nipple is down is because that brake caliber was not designed for this machine.
2015 Ural Patrol (Светлана)
2006 HD Low Rider (sold)
ArgonV
Post by ArgonV » Thu May 09, 2019 3:55 pm
+1 for semi-sintered. Also, do leave some free-play in the rear brake foot pedal. Otherwise when things heat up, your pads will be rubbing on your rotor, get really hot, and burn up.
2016 Ural Retro Classic
jcbigears
Post by jcbigears » Sat May 18, 2019 4:38 am
Bled the brakes, made sure all air bubbles out and fresh fluid and it’s all good. Braking is now consistent. Thanks
2016 Ranger, left hand sidecar, underside of the equator
Post by Albuquralque » Sat May 18, 2019 7:41 am
Glad you got it all sorted out. Now time to ride it!
