2019 MIL (check engine light) stays on
sean0262
Post by sean0262 » Thu May 02, 2019 1:58 am
Howdy folks. After picking up my love 2019 Ural from Heindl Engineering and hauling it 2,580 miles back home to Arizona. I hooked up the digital tachometer. However I then made the mistake of starting my Ural without reconnecting the coil. The Ural rand on one cylinder for a few seconds before I shut it down. reconnected the coil. and fired it right back up. She runs fine. However the MIL light will no shut off. I have disconnected the battery for several hours to reset the ECU. Still the MIL light remains on. Then I have performed the ket toggle on and off for 3 times and still to no avail. HELP!!!!!!!! Is there anyone out there who has had the same problem?
Hey Folks, I'm looking for a solo Ural motorcycle. Any machine will do. from a Wolf, Solo or just a rig without it's sidecar. drop me a PM
Sean's R3W Steering Damper Kits for sale http://www.sovietsteeds.com/forums/view ... 67#p563367
R3W Steering Damper Reviews viewtopic.php?f=11&t=44242
Re: 2019 MIL (check engine light) stays on
Post by Lokiboy » Thu May 02, 2019 5:29 am
Call Heindl
Post by stagewex » Thu May 02, 2019 6:08 am
Call Heindl
X2
You are among a handful of folks that actually own a 2019 now so...Congrats.
Owner/Operator error gonna happen at some point so nice it’s not the rigs issue.
Post by rivers » Thu May 02, 2019 10:41 am
Your owners manual will have a section on how to do and translate the MIL blink-code diagnostic test.
Post by Mr Wazzock » Thu May 02, 2019 5:06 pm
It's possible that it's stored the fault code which now needs clearing. That probably means plugging in the diagnostics computer.
Post by Mr Wazzock » Thu May 02, 2019 5:07 pm
This is the new Keihan EFI system so we're not sure that that part of it works the same at all.
Post by rivers » Thu May 02, 2019 11:37 pm
According to IMZ's web sites online 019 owners manual.
CH 7: EFI Troubleshooting. Blink test included.
atlasheating
Post by atlasheating » Fri May 03, 2019 9:53 am
How long did you run the engine? Sometimes it takes a bit for the light to go off (mine is the '14). Ride it and see.
AndyH
Post by AndyH » Fri May 03, 2019 4:25 pm
Is this a thing for the 2019 model? All the other EFI models ECU's are disconnected when you switch the ignition off, they are not live and do not require power to maintain memory (a bit like a flash drive).
The only hard reset you can do is by using software - if the fault is still there the light will come back on. It can take about 15 kilometers before everything settles down and the MIL light goes off. Pretty much the same distance the Dealers say it will take for a new ECU Map to take hold.
Unless your Dealer advises otherwise, as atlasheating said, ride it and see.
2015 Ural EU Tourist -
Post by RC20 » Sun May 05, 2019 8:30 pm
Was the hookup on the Tachometer the same as others for the Display or is this an add on tach?
Burt1713
Post by Burt1713 » Fri May 10, 2019 7:35 pm
It was activating the tachometer function on the electronics Ural speedometer.
2017 cT "Woody Moose"
BRatigan
Post by BRatigan » Sat Sep 14, 2019 8:25 am
Heindl has a video somewhere that details how to get that CEL to go out. I think its three cycles of the ignition, on and off, but please check with them first.
2008 Buell Ulysses
1978 Yamaha DT 400
1976 Yamaha DT 175
Hodaka Super Rat 125cc year(I forget)
2011 Mazda MX-5 Mountain Racer.
2018 Taco
BRatigan
Post by BRatigan » Sat Sep 14, 2019 9:03 am
2008 Buell Ulysses
1978 Yamaha DT 400
1976 Yamaha DT 175
2018 Taco
Post by Desantnik-VDV » Sat Sep 14, 2019 12:56 pm
He says he already tried that. It's in his post.
Sean, any solution update?
The rest is just history.
vetsurginc
Post by vetsurginc » Sat Sep 14, 2019 7:44 pm
The full three cycle, per the video should cure the light (assuming coil has been reconnected). The error code will still be in the history and requires the diagnostic tool to clear. Video said it was a very picky procedure that had to be followed to the letter.
Doug
2010 R1200RT Gustav
