Light Issue
HassoBoxhead
Light Issue
Post by HassoBoxhead » Wed May 01, 2019 4:41 am
I was riding on the way to the Pentagon for work at 0-dark-thirty this morning when out the the blue every light on the bike went out. Only the brake lights worked when pressed. What do I do to rectify that?
Only difference lately electrically was that I put the Auxbeam LED headlight a couple weeks ago.
Appreciate any help on this!!
2014 Slate Grey Gear Up
Re: Light Issue
Post by hotflash44 » Wed May 01, 2019 4:58 am
this type of situation always start wit the fuse box,good luck. then go back and double check any work you did last and check all connections. :)
Re: Light Issue
Post by Lokiboy » Wed May 01, 2019 6:24 am
Trace the wiring diagram and find a common link. Hotflash44 is probably correct - Ck fuse then look for an exposed wire that’s shorting.
The ignition switch was the cause on mine when I experienced a smiler outage.
90,000 km and counting
Re: Light Issue
Post by Albuquralque » Wed May 01, 2019 7:51 am
Here is a link to the 2014 wiring diagram.
https://static1.squarespace.com/static/ ... iagram.pdf
Fuse 6 is for all the lights except the brake lights. It is the one with the yellow wire coming off of it.
One word of caution, it is possible your fuse box is mounted upside down from the way it is shown in the wiring diagram. There are a number of 2014's out there like this.
Re: Light Issue
Post by S 854 » Wed May 01, 2019 8:43 am
Those are the ultra-rare... special-assembly rigs made by “Navi”—the dyslexic Ivan... :wink:
Trumpetwasher
Re: Light Issue
Post by Trumpetwasher » Wed May 01, 2019 11:42 am
Just a heads-up. The wiring harness is barely capable of handling stock amperage. Just in case you have to delve into that. Don't ask how I know.
Black Power Train
3.89 Final Drive
Reverse Hand Shift
Sidecar Power Panel
Handlebar Power Outlet
Deluxe Seating
Sidecar Side Panels
Armrests
Double-Spring Saddle
Santamaria Foot Rest
Custom Nose Art
Dnepr Leg Shields
XMT-MOTO Hand Guards
All LED lights.
cookiemech
Re: Light Issue
Post by cookiemech » Wed May 01, 2019 12:03 pm
On the 2014 GU that I am refurbishing ("restoring" sounds pretentious), I found a melted wire in the harness that sourced headlamp power. For reasons unfathomable to me, there are no relays in the headlamp circuit this year (and presumably others). This machine is totally stock; no headlamp or other power-drawing modifications had been made to it. The design has the headlamp pulling 5 amperes or more through what appears to be an 18 gauge wire. Not good.
I am of course adding headlamp relays.
2014 Ural Gear-Up
HassoBoxhead
Re: Light Issue
Post by HassoBoxhead » Wed May 01, 2019 12:52 pm
Thank you all for the information! I'll start with the fuse panel tonight when I get home and go from there. Will let you know what transpires.
Re: Light Issue
Post by Mr Wazzock » Wed May 01, 2019 5:05 pm
This is one reason why I added a headlamp relay to mine, so it gets the juice direct from battery. (The second reason was so I could also add a switch to turn the headlight off.)
Re: Light Issue
Post by Mr Wazzock » Wed May 01, 2019 5:15 pm
That's only the "side" lights, fuse 5 (gray wire) does ALL the lights including the headlight. But to confuse matters, power for the side lights goes thru the fusebox twice, fuse 5 and then again thru 6, only so that it can still be fused (#6) when the ignition is in park position. For this and other similar reasons there can be a lot of resistance in the harness causing Voltage drops at the actual bulbs.
HTH
HassoBoxhead
Re: Light Issue
Post by HassoBoxhead » Wed May 01, 2019 6:17 pm
So first replace fuse 5?
HassoBoxhead
Re: Light Issue
Post by HassoBoxhead » Wed May 01, 2019 7:09 pm
Ok, I replaced all the fuses, turned on power, worked fine for 5 seconds,then cut out again.
I’m out of my comfort zone here...
Re: Light Issue
Post by Lokiboy » Wed May 01, 2019 7:40 pm
As I said... my money is on an exposed wire. Also, remove/disconnect the headlight you installed. That should narrow your search.
HassoBoxhead
Re: Light Issue
Post by HassoBoxhead » Wed May 01, 2019 11:21 pm
Sound advice! Thanx!
Re: Light Issue
Post by Mr Wazzock » Thu May 02, 2019 6:05 pm
Yep definitely a short somewhere. Presume it's fuse #5 that fails?
