"14" oops..broken Fuel line plastic nipple at fuel injector
Jdsova
Post by Jdsova » Sat Apr 27, 2019 2:51 pm
Anybody done this... :(
I did an oops. :o I broke the nipple :cry: that is inside the rubber fuel line at injector fuel intake..
I had a batch of bad gas I believed.. engine won't stay running. trouble shooted to the gas...Went to drain gas and the nipple broke of instead of the clip..
any ideas about fixing the plastic nipple...?????? ......is there a screw in type nipple I can buy
J Sova
Peace is that brief glorious moment in history when everybody stands around reloading~" Thomas Jefferson
[*]2014 BMW K1600GTL-E-[*] 2014 2WD Ural Red/October GU-[*]
Past mistresses 2 Urals + 9 previous 2w bikes Marion, Iowa
Re: "14" oops..broken Fuel line plastic nipple at fuel injector
Post by hotflash44 » Sat Apr 27, 2019 2:59 pm
not sure about the replacement nipple probably a dealer part, but next time drain the fuel from the fuel pump quick disconnect attach a length of fuel line into a gas can and turn on the key let the pump do the work. :cheers:
Jdsova
Post by Jdsova » Sat Apr 27, 2019 3:22 pm
Ok, nowwww...…. I find this post;
Re: Parts to Stock
Report
Quote
Post
by Albuquralque » Wed Mar 20, 2019 6:33 am
IMZ-8.1040-15332 Right Hand Injector Fitting and IMZ-8.1040-15331 Left Hand Injector Fitting. These are the small plastic fittings that snap on the end of the fuel injectors that the fuel line connects to.
It is also best to replace the one-time-use clamps in your fuel system and on your airbox tubes and compliance fittings.
For the fuel system clamps, you can get fuel injection clamps from any autoparts store.
For the airbox hose and compliance fitting clamps, you can get replacements here:
https://www.caphardwaresupply.com/colle ... 4345024259
J Sova
Post by Albuquralque » Sat Apr 27, 2019 4:21 pm
And I was just going to post a link to the above!
I havent broken one off, because I carry one of each as spares.
Post by hotflash44 » Sat Apr 27, 2019 4:47 pm
think the link no Buenos.
Eric N
Post by Eric N » Sun Apr 28, 2019 7:13 pm
2013 Retro Solo
2001 Patrol - Sold
Crawford Sales Co.
Post by Crawford Sales Co. » Mon Apr 29, 2019 7:17 pm
I have the fuel rails in stock, right and left and I include a new screw per rail.
Terry Crawford
Crawford Sales
248-437-8107
No personnel messages.Thank you
http://www.crawfordsales.info - Web Site
crawfordsales@sbcglobal.net - Email
Post by eastbloc » Mon Apr 29, 2019 9:09 pm
I recommend a new one and keeping spares in the toolkit, but I can also report I've successfully JB Welded a fuel hat after snapping it clean in half and it's held up.
'02 Patrol
