mis behaving start
Bigflash1
mis behaving start
Post by Bigflash1 » Mon Apr 22, 2019 6:19 pm
New GU with 2k+ miles (had it 2.5 months)
Started being hard to start and won't cold start without
throttle, which causes belching back thru the intake.
Seems to run ok once it's warm. This is a new behavior
as it functioned as it should for the 1st couple of months
Anything I can / should do or is it back to the dealer?
Just wondering, don't want to donate this thing to a dealer as
am so looking fwd to CRAP
2018 Gear up
Dallas, GA (Just outside of ATL)
Re: mis behaving start
Post by Albuquralque » Mon Apr 22, 2019 6:39 pm
Balance throttle bodies and set rpm to 1050 at idle. Make sure engine is at operating temp when adjusting idle.
Bigflash1
Post by Bigflash1 » Mon Apr 22, 2019 7:32 pm
So I really do need to invest in the cable and SW apps to
get into the system then. I figured I need too but was
in need of the collective wisdom.
Thank you!
2018 Gear up
Post by Msblu79 » Tue Apr 23, 2019 12:34 pm
Check some of the simple stuff before you spend any money. Make sure fuel is OK and no water, air filter is clean and not oil soaked, plugs/wires are OK, no intake manifold leaks, valves are adjusted etc. Otherwise if nothing is obvious then I would contact the dealer and let them handle it, perhaps having the latest map installed will fix some or all of the issues. :)
2010 Black Patrol
Bigflash1
Post by Bigflash1 » Tue Apr 23, 2019 1:07 pm
It's been doing it for about 10 days now so
probably 3 tanks of fuel all from different stations.
I did check the air filter. Still looks brand new
it runs fine once warm so it's definitely something associated with temp.
I'll pop the covers off this weekend and check my rocker gaps.
Thanks
2018 Gear up
