Brake light always on
RAMDrive
Post by RAMDrive » Sat Apr 20, 2019 2:35 pm
Found out today my brake light is always on when the key is on. I pulled the brake light fuse and it didn’t go off. It did got off when I pulled the headlight/taillight fuse. Maybe it’s a short somewhere?
Any ideas how to locate the short or someone else experience this?
'17 Ural Patrol -- "Oil Slick"
'99 HD Fatboy -- "The 1-Eleven"
Re: Brake light always on
Post by harryball » Sat Apr 20, 2019 3:43 pm
Both rears, on sidecar too?
Disco the sidecar, see if the problem goes away or stays with the bike. Then, I'd start tracing the wire from the taillight back.
Any mods? Accessory lights?
Donbmw
Post by Donbmw » Sat Apr 20, 2019 4:57 pm
On my 2015 I have had the rear brake switch stick in the on position a few times.
Don
Post by chaos2 » Sat Apr 20, 2019 6:01 pm
unlikely, but I once had one of the filaments on a dual filament bulb drop down and short out the other filament. I think the sidecar brakelight is dual filament, could be the problem but that's probably way too easy.
heindlengineeringural
Post by heindlengineeringural » Sat Apr 20, 2019 8:34 pm
Front brake switch is likely loose. It is held on by a small screw. If you don't hear a "click" when you lighty tap the lever, this is the problem. Check and adjust.
Heindl Engineering, LLC
Ural Dealer in Southwest Ohio
(937) 787-3686
www.heindlengineering.com
sales@heindlengineering.com
Daisy Cutter
Post by Daisy Cutter » Sun Apr 21, 2019 7:37 am
Had the same issue with my 17. turned out to be a bad front brake switch.
North Alabama
2017 Ural Gear Up
Post by S 854 » Sun Apr 21, 2019 9:22 am
I’ve experienced the same thing... drove me batty attempting to find the problem in my pickup...
...and while yer inside the tail light, check the connections on the back of the reflector... I had one loosen and give me grief...
Post by Mr Wazzock » Sun Apr 21, 2019 9:32 am
But he says, take brake fuse out no difference, take lights fuse out, it goes out, says to me there's a short between the two in the sidecar rear lamp. These lamps are not the most brilliant design must be said, and are quite crude internally. The sidecar bulb is a double filament, so has two 'live' terminals close together, my guess at this stage is bulb is slightly skewed so bridging them together. Just a guess but early on I made the mistake of putting a dab of WD40 on the bulb bases of mine, this made the sidecar bulb too loose and play silly buggers and not want to stay in its socket, I ended up having to use loctite to make it stay put!
Eric N
Post by Eric N » Sun Apr 21, 2019 12:11 pm
1157 bulbs can get reversed. Pull bulb, turn it 180 degrees, put bulb back in.
2013 Retro Solo
2001 Patrol - Sold
Post by Mr Wazzock » Sun Apr 21, 2019 12:26 pm
That as well!
But I'm thinking maybe slightly turned so that one of the ellyptical contacts on the base is bridging both copper strips.
Mikey
Post by Mikey » Sun Apr 21, 2019 2:47 pm
Any chance it is the rear brake switch? Mine needed adjustments after I found it on all the time.
2017 Gear-up Forest fog
RAMDrive
Post by RAMDrive » Sun Apr 21, 2019 11:16 pm
Found the fix. I removed each bulb, then replaced one at a time and tested between. The hack tail/brake light had the incorrect bulb in it; Just as stated, a single filament bulb will fit when it should be a dual. The single pole caused the two leads to short.
Thanks again the to best moto community around! :boogie:
Post by S 854 » Sun Apr 21, 2019 11:27 pm
Like most things Ural... you’ll find it’s usually an easy fix... it’s the finding-the-issue that’s the problem... :lol:
Thanks for letting us know the outcome... it’ll help others in the future...
Post by Mr Wazzock » Mon Apr 22, 2019 5:48 pm
DOH!! That'll do it sure nuff.
85 Proof
Post by 85 Proof » Mon Jul 22, 2019 12:27 pm
I have been periodically plagued this condition and have solved it by spraying CRC 2-26 or other contact cleaners up into the Brake light switch. WD-40 may work OK also.
