2018 Knocking at Idle
Ajax
Post by Ajax » Sat Apr 06, 2019 7:22 pm
Just noticed this knocking today on this 2018 GU with 3500 miles on it. Any help figuring it out would be appreciated.
2004 Tourist 65k km (new to me 2018 @ 48k km)
2018 Gear Up that I have the pleasure of maintaining for the girlfriend
Re: 2018 Knocking at Idle
Post by Lofty » Sat Apr 06, 2019 7:54 pm
Prior to taking the video, did you verify the correct valve clearances when the engine was cold?
Ajax
Post by Ajax » Sat Apr 06, 2019 8:14 pm
Yes. Plugs as well.
Thought maybe fuel starvation... picked up a new filter that needs to installed to see if that's any help.
treeman1942
Post by treeman1942 » Sat Apr 06, 2019 9:00 pm
As you know, "girlfriends" can be a problem, even more than the Ural. :cheers:
2019 Ural Gear Up, OD Green
2014 Burgman 400/A
2008 Piaggio MP3250
Whizzer Motorbike
Will Rogers
Ajax
Post by Ajax » Sat Apr 06, 2019 9:05 pm
Lol. Yeah. It was hell trying to ask her if she heard this noise before....watching the vid she still couldn't hear it, she just heard the normal vavle noise.
When I get that filter on I'll check the noise again with a engine stethoscope to pin point the area better.
treeman1942
Post by treeman1942 » Sat Apr 06, 2019 9:16 pm
Good luck with diagnosing the problem. Just a nonsensical tidbit here, girlfriends can be a real pain. I've found that dogs make better companions, really have. Granted, something is missing, but no issues, just total devotion. My dog Pugsley is unconditionally devoted to me, and gotta say, never found a woman like that. Granted, something is missing but the devotion, true love, etc, is just hard to find in humankind. I do envy you if you've found a true soulmate.
2014 Burgman 400/A
2008 Piaggio MP3250
Whizzer Motorbike
Will Rogers
Ajax
Post by Ajax » Sat Apr 06, 2019 10:08 pm
Well I have the dog in my rig and she has her own rig. Lol
Post by hotflash44 » Sun Apr 07, 2019 6:46 am
sounds like a exhaust leak i had on a motorcycle once, easy to check.hope its that minor. :cheers:
47ohv
Post by 47ohv » Sun Apr 07, 2019 10:18 am
sounds like valve adjustment to me
Post by rivers » Sun Apr 07, 2019 10:50 am
Just at idle/low RPM huh? Exhaust leak is a strong possibility. Before you start tearing stuff apart, get a couple feet(3?) of garden hose, put one end to your ear and run the other end over any exh connections, head/cyl connections etc. Easy/quick to to do just use a hollow medium rather than solid. On and 018 likely just assembly bind/stress/misalignment rather than wear.
Ajax
Post by Ajax » Mon Apr 08, 2019 10:28 pm
I checked the vavle clearance and installed the needed fuel filter but it's still knocking non rhythmically. Found my engine stethoscope and traced the sound near the area of the crank on the engine case.
Maybe it's time to let the dealer deal with this now since it's under warranty?
