I may need a new clutch
Re: I may need a new clutch
Post by RC20 » Wed Apr 17, 2019 6:09 pm
Original owner riding the shifter with his foot?
Post by windmill » Thu Apr 18, 2019 11:24 am
Scott, good to see no damage to the gears. Even the short distance I rode it, the grunch it made when it popped out of gear made me cringe.
Post by gobium » Thu Apr 18, 2019 12:07 pm
What would happen? If shifting limits are over or under set.
Will that put stress on shift sleeve and fork?
Post by Albuquralque » Thu Apr 18, 2019 1:12 pm
So are you suggesting that from the factory it's possible that shifting limits aren't set correctly?
So far, there have been four different 2014 gearboxes that have lost third gear to this problem.
Post by Tomcatfixer » Thu Apr 18, 2019 1:18 pm
I suspect that a too-short shift stop would result in rounded-off engagement dogs and a transmission that easily pops out of gear. A shift stop set too far out would allow excessive pressure to be applied to the shift forks, which could bend them, thereby hindering gear selection.
Post by gobium » Thu Apr 18, 2019 2:07 pm
Dont know.
Shift limits set movements on quadrant.
Quadrant moves moves 2 shift forks
Forks move selector gear sleeves
The way I see it, bad metal or tracing to shift limit settings
Either ways 14 gb models are more prone to loosing 3-4 gears but not uncommon to other years
Post by gobium » Thu Apr 18, 2019 2:14 pm
Not new but you can see the fork is tight in shift sleeve
Post by hotflash44 » Fri Apr 19, 2019 8:23 am
looks pretty obvious from both pictures that the shift fork is rubbing on one side, either the gear cluster has play or the shift limit adjuster is pulling the fork to the side. no help from me, just a observation. :? :lurker:
atlasheating
Post by atlasheating » Fri Apr 19, 2019 9:40 am
Barry, thanks for your help. I have only put about 75KM on it with the shifting problem
Mine has about 1/16" play
atlasheating
Post by atlasheating » Fri Apr 19, 2019 1:17 pm
I took some more pics showing the gap between the shifting fork and the 3/4 gear selector
ImageIMG_2337 by atlasheating, on Flickr
Here is one with a screwdriver in the gap. There is alot of slop. There is no slop on the 1/2 gear selector and fork
ImageIMG_2338 by atlasheating, on Flickr
atlasheating
Post by atlasheating » Tue Apr 23, 2019 7:06 pm
Well, I got my parts today and I have re assembled the transmission. That kick starter spring was a bear! I will put everything together later..... Stay tuned.
Post by Albuquralque » Tue Apr 23, 2019 9:49 pm
Did you take pics of the new fork and shift sleeve to show how they fit together?
atlasheating
Post by atlasheating » Wed Apr 24, 2019 7:43 am
no but it looks like Van's pic
Post by gobium » Wed Apr 24, 2019 8:32 am
Remember ccw to load the kicker spring
Same rotation as a kicker
atlasheating
Post by atlasheating » Wed Apr 24, 2019 3:03 pm
That thing was Hard to do. I wasn't sure I would get it, but it finally went together.
Ready for the final drive and rear wheel and we will see.....
