I may need a new clutch
atlasheating
Re: I may need a new clutch
Post by atlasheating » Tue Apr 02, 2019 3:57 pm
Well it runs right. I don't know what I did, but I got the engine to idle like it is supposed to.
Now back to the original problem.
It may be the gearbox...
When putting a load on 3rd gear it is like it is jumping in and out. Now it is making a grinding noise....
I think I will wait and take it to the dealer....
Post by gobium » Tue Apr 02, 2019 3:58 pm
It might be the shift limit settings
Post by gobium » Tue Apr 02, 2019 4:00 pm
atlasheating
Post by atlasheating » Tue Apr 02, 2019 7:10 pm
So do you think those settings got out of wack?
Post by gobium » Tue Apr 02, 2019 7:15 pm
What do you got to loose?
Worth a try.
Post by Albuquralque » Tue Apr 02, 2019 7:36 pm
See my and Chaos2 post one page 1
atlasheating
Post by atlasheating » Wed Apr 03, 2019 1:54 pm
Definitely 3rd gear is going out.
atlasheating
Post by atlasheating » Tue Apr 16, 2019 6:41 pm
So I finally tore into the transmission. I found the 3-4 shifting fork was worn and the shifting sleeve was really worn. I have ordered new parts.
atlasheating
Post by atlasheating » Tue Apr 16, 2019 6:48 pm
Here are some pics of the damage:
ImageIMG_2330 by atlasheating, on Flickr
ImageIMG_2331 by atlasheating, on Flickr
ImageIMG_2327 by atlasheating, on Flickr
Post by Albuquralque » Tue Apr 16, 2019 9:20 pm
How many km's on the gearbox?
Mine did the same thing at somewhere around 45000 kms.
atlasheating
Post by atlasheating » Wed Apr 17, 2019 12:07 pm
25,000KMs Most of them with the original owner.
Post by gobium » Wed Apr 17, 2019 1:44 pm
So why do you think. your shift fork and gear sleeve selector wore? It grooved each other
atlasheating
Post by atlasheating » Wed Apr 17, 2019 1:46 pm
I do not know why. Everything else looks fine. The wear is indicative of the symptoms. Maybe at one time the gearbox was low on oil???
Post by Albuquralque » Wed Apr 17, 2019 2:14 pm
Doubtful on the low oil assumption.
As I am aware of today, this is the fourth 2014 gearbox that has had this same problem.
atlasheating
Post by atlasheating » Wed Apr 17, 2019 2:30 pm
Hopefully that is the only problem.
