I may need a new clutch
atlasheating
Re: I may need a new clutch
Post by atlasheating » Wed Mar 20, 2019 1:29 pm
I live in Kent WA. Near Redmond...
I am starting in on the transmission removal right now.
Van, your videos have been enjoyable to watch and I have learned alot. Thanks
atlasheating
Post by atlasheating » Wed Mar 20, 2019 3:05 pm
Yep it is the splines.
atlasheating
Post by atlasheating » Wed Mar 20, 2019 3:10 pm
ImageIMG_2305 by atlasheating, on Flickr
ImageIMG_2307 by atlasheating, on Flickr
Post by hotflash44 » Wed Mar 20, 2019 4:27 pm
do you need to replace the trans spline or can it be cleaned up. :?:
Post by chaos2 » Wed Mar 20, 2019 5:23 pm
as bad as those are wouldn't they have to be sheared off to make it lurch?
Manscout
Post by Manscout » Wed Mar 20, 2019 5:30 pm
That is horrible!
2011 Ural Patrol
Gillette, Wy
Instagram: manscoutwyo
atlasheating
Post by atlasheating » Wed Mar 20, 2019 7:22 pm
I think it was starting to fail and it was telling me it was time for a change.
Post by Mr Wazzock » Wed Mar 20, 2019 7:29 pm
I tend to agree, that wouldn't slip. They'd have to be broken off.
Post by Mr Wazzock » Wed Mar 20, 2019 7:30 pm
PS: however there's enough play to produce a lurching type behaviour, possibly. :?:
Post by chaos2 » Wed Mar 20, 2019 7:39 pm
Good point, curious if new clutch plates will cure the issue
Post by Tomcatfixer » Wed Mar 20, 2019 8:11 pm
That is VERY impressive.
I'm glad you identified the problem and that it's an easy fix.
Post by S 854 » Wed Mar 20, 2019 11:33 pm
Fretting caused by the rear clutch disc appears more severe than the front... at least as far as the gearbox splines are concerned...
Wonder if it’s possible one of the discs would get cockeyed just enough to where the clutch wouldn’t lock up as it should on full release?
Regardless... that’s a new one on me... up til now all the issues I’m aware of both discs caused the same amount of wear on the splined shaft...
Pay attention and you’ll learn something new every day...
Post by gobium » Thu Mar 21, 2019 7:51 am
This is what I use on all my BMW and Ural
Post by Msblu79 » Thu Mar 21, 2019 8:29 am
I had the same failure on mine. The splines were almost gone and the tranny shaft was badly damaged to the point I had to change it out. Yours is still OK and I would run it for now and just change the clutch plates out. They wore out rather quickly it seems, mine made it to about 80K klicks before it started acting up but by then the damage was complete. You caught it early enough to save the tranny shaft which will save you a bunch of money & frustration. :)
2010 Black Patrol 90,000km's
Ironhand
Post by Ironhand » Thu Mar 21, 2019 10:36 am
Those notches worn into the tranny shaft are not a concern?
2015 Ural Gear Up
2012 Yamaha Super Tenere
2008 Honda XR650L
2003 Yamaha FZ1
