I may need a new clutch
atlasheating
Post by atlasheating » Mon Mar 18, 2019 1:58 pm
So when I was getting onto a freeway onramp I felt the Ural kind of lurch in 2nd and then when revving it up in 3rd I felt the lurch again.
It didn't do that again until I rode it again on Saturday. It is like pulling the clutch briefly in while powering down the road (mostly in 3rd gear)
It is doing it more and more. The transmission and rear end are not making any noise. I am thinking the splines on the clutch are wearing out.
2014 Patrol with 25,500KM. I bought it used, so the first 22,000KM I do not know how it was ridden.
What do you think??
If I replace the clutch, should I just replace the clutch discs?
Re: I may need a new clutch
Post by chaos2 » Mon Mar 18, 2019 2:06 pm
Most likely the transmission, mine was doing that then it started jumping out of gear in 3rd
Post by Mr Wazzock » Mon Mar 18, 2019 2:07 pm
If clutch splines are slipping then it would make this horrible noise -
Is it making that noise? Too loud to be missed or not heard I would have thought.
Post by Mr Wazzock » Mon Mar 18, 2019 2:09 pm
Possibles, dogs are worn or selector bent?
atlasheating
Post by atlasheating » Mon Mar 18, 2019 2:48 pm
I was thinking the clutch was starting to fail....
Post by S 854 » Tue Mar 19, 2019 8:54 am
How’s your clutch adjustment?
You might also swing the steering through it’s arc while watching the clutch arm down at the tranny... if the PO misrouted the cable it could be hanging up somewhere causing it to tighten with handlebar movement...
Or...
You may need a new clutch... :wink:
Post by chaos2 » Tue Mar 19, 2019 9:28 am
Worn dogs and selectors! fixed it last summer and it's been a pleasure to use since
Post by gobium » Tue Mar 19, 2019 10:40 am
Did the last owner did the clutch himself?
My money on backward clutch plates
atlasheating
Post by atlasheating » Tue Mar 19, 2019 5:23 pm
Van,
I don't think the previous owner touched the clutch. I asked him specifically about the clutch and he said it was good. I have ridden it about 3,000KM without any problems.
Post by gobium » Tue Mar 19, 2019 6:06 pm
Van,
Regardless.
Pull the gear box look at clutch
But first pull the rear wheel and look at the hub splines you might get lucky
Post by Albuquralque » Tue Mar 19, 2019 6:15 pm
+1.....mine did the same thing. Then eventually third gear went out totally.
atlasheating
Post by atlasheating » Tue Mar 19, 2019 6:31 pm
"Regardless.
But first pull the rear wheel and look at the hub splines you might get lucky"
I can do that right now. I never thought of the wheel hub. I have an extra one on my spare.
idaho270
Post by idaho270 » Tue Mar 19, 2019 7:53 pm
my clutch was making the samenoise
atlasheating
Post by atlasheating » Wed Mar 20, 2019 9:15 am
No Such Luck. I pulled the rear wheel and the splines on that are fine. I will get to the transmission today or tomorrow.
Post by gobium » Wed Mar 20, 2019 10:44 am
Where r u located.
Clutch job is easy, 3hrs? 6 pack
