New float sensor for 2014 to 2017
Donbmw
Re: New float sensor for 2014 to 2017
Post by Donbmw » Wed Feb 27, 2019 2:40 pm
wooden nickel wrote:
Wed Feb 27, 2019 2:23 pm
Timer is just a delay on. It just means the switch has to be on for at least the delay time before the indicator lights up. Even if the gas is sloshing slow, the indicator still won't flash any quicker than the time delay. That isn't too clear. What I mean is that I have my delay set to 5 seconds. The sensor has to be uncovered for at least 5 seconds before the indicator lights up and then even if the gas just splashes on the sensor, the light stays off for at least 5 seconds.
It at least stops the rapid blinking and it also means the gas is actually getting low before I get any blinking. I run it that low so seldom, I have to think for a few seconds to remember what the weird indicator light means.
This is not about the old style fuel sensor. It is about the new float fuel sensor they are installing to replace to optical one.
Don
Post by windmill » Wed Feb 27, 2019 3:05 pm
From what he explained, it shouldn't matter which sensor is used as it doesn't change how sloshing fuel effects them, it changes how long the sensor needs to be activated before the light comes on.
Post by Mr Wazzock » Wed Feb 27, 2019 4:32 pm
Donbmw wrote:
Wed Feb 27, 2019 11:28 am
But know it is not going out when the tank is full.
Seems like it's stuck?
Donbmw
Post by Donbmw » Wed Feb 27, 2019 5:17 pm
I have thought that it maybe. Every now and then it will go of but come back on. I am going to try and almost run out of gas and take the bike to work. Will use a borescope an see if there is something in the tank letting it get hung. It worked for almost 3 months then 3 weeks ago it has been staying on steady with occasionally going off and back on.
Don
Post by Tomcatfixer » Wed Feb 27, 2019 6:10 pm
Sounds like a poor electrical connection to me. Have you checked your wiring?
Post by wooden nickel » Wed Feb 27, 2019 7:30 pm
One of the problems with small float sensors is that the small float don't have the mass to push past any fouling or varnish. I know the early floats Ural used were also at an angle which would exacerbate the problem. I am not saying this is happening. I am just saying small float switches are more susceptible to any impediments than the larger units. Designing small, rugged, relatively inexpensive, fuel compatible sensors is a tough game.
Donbmw
Post by Donbmw » Wed Feb 27, 2019 8:13 pm
Yes I have checked the connections. No amount of playing with the plug and wiring would make the light go on and off. When the dealer installed the new switch they solder wires on the plug from the old sensor.
Don
Post by windmill » Sat Mar 02, 2019 2:03 pm
I ordered the timer, If possible could you show how you wired the timer?
Post by wooden nickel » Sat Mar 02, 2019 6:57 pm
It's been awhile Barry. Let me see if I can find it.
Post by wooden nickel » Sat Mar 02, 2019 7:33 pm
Bad news Barry, I checked and that is the timer I ordered when I was getting an inverted function sensor. I couldn't get it to work without adding another relay. I ordered this relay from Bulgaria.
https://www.ebay.com/itm/Delay-Time-Rel ... 364592646f
Any 12 volt straight on delay relay will work.
Post by windmill » Sat Mar 02, 2019 7:49 pm
Interesting, its listed as functioning as either a No or NC relay.
Post by wooden nickel » Sat Mar 02, 2019 9:13 pm
Yeah it does that but if I remember correctly, it doesn't just turn on after being triggered for a set time. I forget how it screwed me up but I know it was more efficient to start over rather than make that one work.
Post by windmill » Sat Mar 02, 2019 10:18 pm
Played it safe and canceled it, and ordered 5A timer, http://timers.shop/Multi-Functional-Timers_c_15.html
Donbmw
Post by Donbmw » Fri Mar 08, 2019 8:40 pm
Follow up on the float fuel level sensor. Today I was down to about a gallon of fuel left in tank. Used a borescope to see if I coul see something that could keep the float stuck in the low fuel position. Could not see anything. Drained all the fuel and removed the tank. With switch in the on position and moving the tank so the float would be in the empty and full position. I found that the tank in a position that the float should give you a full tank and the fuel light out. It would the float would stick in the low fuel position. The float would stay in the low fuel position until gave the tank a bum. Then it would fall to the full tank position. I removed the float sensor and still could not see any reason for it to stick. What I did find with it not installed. With moving the sensor the slight angle to be as close to the position it is mounted in the tank. The float would not slide on its own to the full position. The float level sensor when installed looks to be about a 30* angle. After having the sensor out of fuel for a couple hours I found that the float would slide on the shaft and turn the light on and off with very little tilt from the low to full readings. The only thing I can come up with for this not working is the float seating in the fuel and swelling to let it stick. If it wasn’t such a pain in the a$$ to install and remove by the way this float sensor is made you could fine tune the float position closer to one gallon left and open the clearance of the float and shaft so it might not stick.
Don
Post by wooden nickel » Fri Mar 08, 2019 9:30 pm
Neat timer. That ought to do it.
