Weird headlight issue
HassoBoxhead
Post by HassoBoxhead » Thu Feb 14, 2019 6:22 pm
About six weeks ago, I noticed my headlight was dim and not knowing how long that light had been on the rig (bought it used), I replaced it with a silverstar. Initially all was well, then it too started to dim so I used the high beam, which burnt out after a week. So, I bought a Hella H4 unit and the high beam is awesome, but the low beam is barely bright enough to illuminate in front of me.
Any thoughts on what could be causing this and how to go about rectifying the issue?
Thank in advance for the help!
2014 Slate Grey Gear Up
Re: Weird headlight issue
Post by Tomcatfixer » Thu Feb 14, 2019 7:03 pm
Voltage drop in the low beam circuit?
Have you checked and/or cleaned your electrical connections?
Post by rivers » Thu Feb 14, 2019 7:24 pm
+1
I'm no electrician but that'd be where I'd start. I think by 014 Ural no longer powered the headlamp via a relay so you get less current flow running through the cheap switch gear/wiring. Add corrosion and performance can deteriorate noticeably. When my 014 lamp gets iffy, I'll rewire the headlamp circuit via a relay.
Post by Wildhorse Cafe » Thu Feb 14, 2019 9:24 pm
Down load an electrical schematic and check all the connection points eg. corroded connections, loose connections, loose grounds. Snug every thing even if it looks good. It is just tracing wires and not voodoo.
HassoBoxhead
Post by HassoBoxhead » Thu Feb 14, 2019 10:50 pm
That makes sense, Wildhorse, I think I’ll start there.
Post by Mr Wazzock » Fri Feb 15, 2019 2:48 pm
I think so too.
I eliminated all the "miles" of wiring, a gazillion connectors, two fuses in series FFS and the lighting switch(es) by doing this:
Note also it bypasses ignition switch, so that gets an easier life not having the headlamp current going thru it all the time.
HTH
Post by Mr Wazzock » Fri Feb 15, 2019 2:52 pm
PS: note also extra switch (below, left) so I can manually turn the headlamp off. I am now in the habit of always having it turned off for starting.
Post by Wildhorse Cafe » Fri Feb 15, 2019 3:45 pm
I think so too.
HTH
Much of the wiring is not related to the headlight circuit and can be ignored. Familiarize yourself with the headlight circuit by tracing it out on the diagram using a highlighter marker, Then test by slitting the circuit in half and use a jumper to ground to test the first half of the circuit. If it tests good then split the remaining half; or if the first half tests bad, slit the first half of the circuit and test again. Test and split, test and split. By splitting you can avoid unnecessarily testing everything and can narrow it down to a component or connection fairly fast. But the first thing for any troubleshooting is a good visual inspection to find the obvious. You know, " Why there's your problem.":foilhead:
Post by Wildhorse Cafe » Sat Mar 02, 2019 12:57 pm
How did your head light issue turn out? Don't leave us hanging.
Post by Mr Wazzock » Sun Mar 03, 2019 10:10 am
+1
This is often a sign of a bad or loose connection or earth, unbeknownst to you it's rapidly flickering on and off while you're riding, that kills a bulb in short order.
I remember years ago following an old bike with a flickering tail light, but every time he stopped it was lit properly, so just looking to see if lights are working as a maintenance check or before setting off for a run wouldn't show the problem.
HassoBoxhead
Post by HassoBoxhead » Sun Mar 03, 2019 1:57 pm
I haven’t had a chance to have it outside to work on with all the crappy weather we’ve had lately. (I also dread doing anything electrical, so I’m pretty sure there’s a fair amount of subconscious procrastination coming into play). Really appreciate all the info!!
Post by Wildhorse Cafe » Sun Mar 03, 2019 6:49 pm
+1
Tail light have been an issue in the past for friends of mine. I would take of the lens for an inspection. And just so you know the outer connection is positive on Ural tail lights and the center is negative, weird but true.
Post by Mr Wazzock » Mon Mar 04, 2019 1:26 pm
Yep! :D
And the little solder tag washers (2 off?) must be good. Guess how I know ... and the tiny screws only go into plastic so don't try to welly them up tight ...
aquaskiman
Post by aquaskiman » Sun Mar 10, 2019 3:15 pm
My 2014 GP had the same trouble but with both high and low. it was a voltage drop through the ignition switch.
2014 Gear Up Sedalia Co
