Machinegun mount
tgellen
Machinegun mount
Post by tgellen » Sun Feb 10, 2019 3:35 pm
I finally scraped together the money for it (old timers garage), but have run into a snag...the last two pics say it all. Suggestions?
2015 Ural Gear-Up
Bethlehem PA
Re: Machinegun mount
Post by hotflash44 » Sun Feb 10, 2019 4:27 pm
well there are several possibilities, IMO, looking at ww2 Zundapp/BMW pictures it sets further forward, but the spot light might be in the way. would assume the side car cover attachment could be removed or attached to the mount leg im sure you can make the mods. if your just going to install the gun mount for shows with your Mg-42 some sort of quick mount system might work. big issue is the location of the light and the side car cover snaps. good luck! look at this for ideas www.youtube.com/watch?v=wUtIXHhVRbU
Post by Tomcatfixer » Sun Feb 10, 2019 4:45 pm
Remove the two outer common sense fasteners, install your machine gun mount, purchase some more fasteners here: https://www.amazon.com/Common-Fasteners ... B01N6RHAP0 , then modify your tonneau cover. No big deal.
Burt1713
Post by Burt1713 » Sun Feb 10, 2019 6:23 pm
Or you could have a new tonneau made at an upholstery shop.
2017 cT "Woody Moose"
Post by Tomcatfixer » Sun Feb 10, 2019 6:35 pm
By the way, TJ, if you want to restore that purple tonneau cover back to it's original black glory, just buy a can of Krylon Fusion paint and spray it down. This paint is formulated to adhere to plastic, so it's perfect for reinvigorating that faded Cordura.
Post by hotflash44 » Sun Feb 10, 2019 7:01 pm
here is another bike with your exact gun mount, seems all are missing the spot light. /www.youtube.com/watch?v=VJl9cM3lOVA&t=174s
tgellen
Post by tgellen » Sun Feb 10, 2019 11:35 pm
Yeah, it looks like the spotlight has to be moved, if I want to keep it. Question is: Do I want to move it forward to where a pintle mount would go, or to the sidecar fender?
2015 Ural Gear-Up
Bethlehem PA
Post by windmill » Mon Feb 11, 2019 12:01 am
How often do you use it?
I converted mine to a second headlight, so I would move it forward just enough to clear. If rarely or never used, maybe just remove it, on the fender It would probably be in the way, and cause too much peripheral glare like having someone tailgating you with their high beams on.
cateyetech
Post by cateyetech » Mon Feb 11, 2019 12:40 am
Hey tgellen
Why don't you notch out the mg mount to clear your cover tabs?
:foilhead:
Charlie ╭∩╮(-_-)╭∩╮
2003 Gear-Up Ромашка Мзй
2000 Patrol Teh Урал
Post by Tomcatfixer » Mon Feb 11, 2019 6:20 am
I don't think you're grasping how easy the common sense fasteners are to remove and install. Or perhaps it's modifying the tonneau cover that's giving you pause? I don't understand why you must sacrifice the spotlight if you would prefer to keep it.
tgellen
Post by tgellen » Mon Feb 11, 2019 7:08 pm
I'm hesitant because I thought this was going to be simply drilling a few holes and installing it, but now it's getting more complicated.
It's also modifying the cover and the fasteners are pop-riveted in place, and I'm sure more will crop up along the way.
I was hoping for simple.
I deal with complicated stuff everyday (repairing/restoring antique jewelry)
Oh, well.
Now to find those twin Panzer lights.....
2015 Ural Gear-Up
Bethlehem PA
tgellen
Post by tgellen » Mon Feb 11, 2019 7:10 pm
Hey tgellen
:foilhead:
It's right under the upright part on that side.
2015 Ural Gear-Up
Bethlehem PA
Post by Tomcatfixer » Mon Feb 11, 2019 7:12 pm
Drilling out and installing new pop-rivets is remarkably simple. Modifying the cover may take a professional, but the small amount of alteration necessary should incur minimal expense.
